Question about Reddy R70ET Utility Heater
REDDY HEATER PRO 70
COMES ON AND FIRES BUT WON'T STAY RUNNING ? GOT FUEL AND FIRE. WHAT IS WRONG?
  • 2 more comments
  • Anonymous Jan 02, 2008
    I have a old Reddy Heater that will run and then it will just shut down in a clowd of smoke what could it be
  • djmann Jan 09, 2008
    installed a new fuel nozzle and sparkplug , has spark and fuel ,but does not ignite
  • honestrandy Feb 23, 2008
    heater starts runs about 30 seconds and quits. nozzle sprays good &I put in a new glow plug, what next?
  • papatech Nov 30, 2008
    hello if the heater will run with the cover off then it could be low fuel pressure , check for a cracked pump end cover . the cover on my 110 was cracked i could appy thumb & forefinger pressure & heater would go back into full roar , PAPATECH
I had the problem on my reddy 70 ,30 seconds.and would die.long story short,it was the capacitors.capacitors go bad.took mine off and went down to radio shack and matched them up with new ones.the numbers are on them.solderd them back on and has been running perfect for 2 years. the capacitors are on the chip board for those who dont know.blue and black and look like little pop cans,cant miss them.i hope this helps,should only cost $2.00 to fix.
Posted on Feb 06, 2009
I have a Reddy Heater R100 that ran just fine until one day it
wouldn't ignite. I took the cover off to see if it was sparking and it
ran just fine with the cover off. I got on the Internet to see if there
was a definitive answer as to why it would only run with the cover off;
there wasn't. So I decided to troubleshoot it step by step instead of
replacing everything at once. You can thank me later.
Step 1: Dumped out old fuel, made sure the tank was completely dry and
clean. Put in fresh kerosene. This is an absolutely hideous job.
Result: Still would only burn with the cover off. Said bad words.
Step 2: Replaced all three filters. Result: Still would only burn with
the cover off. Didn't say bad words, just thought them.
Step 3: Removed the end filter cover and pushed on the pressure relief
ball. It seemed to be stuck.
so I marked the relief screw, counted the exact number of turns to take
it out, and washed the end filter cover and small parts with Dawn
dishwashing detergent. Harsh solvents can melt the plastic on the end
filter cover. Blew everthing dry. Put a little oil on the spring and
ball so they wouldn't rust. Put the relief screw, spring and ball
together, making sure I turned the screw back in the same number of
turns that I took it out with, within a tolerance of about 1/8 turn.
Step 3: Downloaded a manual from:
http://www.desatech.com/manuals.cgi?products=Construction%20Heaters to
find out the spark plug gap. They didn't have one for an R100 so I used
the one for a R100EDI. I cleaned and set the spark plug gap to .055".
I think later heaters use .075" or .085". Check your manual. Result:
Step 4: Removed the nozzle. Put a clean paper towel under the input and
sprayed carburetor cleaner into the output end of the nozzle,
backflushing it. Four or five pieces of crud came out, onto the paper
towel. Really cleaned the nozzle good. Blew it off with compressed air
to make sure all of the carburetor cleaner was evaporated. Replaced the
nozzle. Result: O frabjous day! It worked just fine for about a half
hour, then it started coughing and smoking.
Step 5: Removed the nozzle again. Put a clean paper towel under the
input and sprayed carburetor cleaner into the output end of the nozzle,
backflushing it again. Four or five pieces of crud came out, onto the
paper towel, again. Really cleaned the nozzle good, again. Cleaned the
fuel filter and the upper fuel line. Made sure everything evaporated
before I put it back together. Result: works great with the cover on.
Ran the tank of fresh fuel empty. Put the original fuel back in, it
works too.
So, if in the future, I have the problem where it doesn't burn with the
cover on, I'm going to start with the nozzle, upper fuel line and fuel
filter.
Posted on Jan 13, 2009
Cracked fuel pump cover
Posted on Nov 30, 2008
  • papatech Dec 02, 2008
    sorry, incorrect air mixture.not fuel pressure , sorry used to working on automobiles !
Check filter down inside tank. Also you may have large chunks of trash that will not fit into the filter. when heater shuts off it drop the trash and when you start it back up it picks the trash up again causing the symtoms you desribe.
Posted on Jan 14, 2008
  • 625 Answers
Change the millivolt generator
Posted on Dec 26, 2007
70 thermstat controled replaced igniter,filters,spray nosle ,hoses last year. worked fine until last week. would only run about 3 min. had to start it 3 or 4 times. then just stoped . found crack in...
Well this one is trying to detect flame, please try checking the fire eye clean the lens with windex and a terry cloth rag and try to fire it up. Make sure that this eye has an unobstructed view to the flame, not a correct thing to do but jump the eye out and see if you run longer if so replace the fire eye.
Dec 13, 2010 | Reddy R70ET Utility Heater
Reddy heater has problem staying on
Check the foam filters located in the back, their is also a primary air adjustment slot in the back try adjusting that each time you fire it to see if you can get it to stay on.
Can you see the fuel oil coming out of the nossle? If
not clean it. If it has a cad cell that could be bad or dirty, you might have to bypass it to see if that is the
problem.
Jan 15, 2010 | Reddy HEATER RH125T 125,000-BTU...
60000 heater kerosene fires up but shuts off shortly after
Check the entire fuel like to the tank. They tend to break, plug up, etc. which causes a lot of problems. The strainer in the bottom also plugs up. Rick
Apr 08, 2009 | Reddy Heater 60,000 BTU Kerosene...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater teasing me:)
sound like there is dirt and stuff in the fuel tank.when the heater fires up it pulls this stuff up into the filter.as it runs it plugs the filter off causing the heater to shut off.whe it shuts off the garbage falls back into the tank.when you refire the heater it pulls the garbage back up again.it never pulls it up the same so the time verys every time
Feb 18, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
When heater starts it does not always light, I get a C3 code
the ignitor is faulty, mine also did that and I noticed one night that it was shorting out right from the ignition box. I put in a new ignitor and flame sensor and it's fine now. All ignitors are basically the same you just have to do some creative wireing. reddyparts.com still has most parts for your heater.
Jan 20, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater pro 110
Need parts for readdy Heater Pro 110 New
Jan 14, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy R70ET Utility Heater Logo
1,343 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
