Question about HP LaserJet 4L Printer
No power - all status lights are off
All status lights are off even after holding down the front panel button for 10 seconds with power cord plugged into a working wall receptacle. Printer appears to be dead. It had no prior troubles since new!
Could it be a power supply problem? Is there a power supply fuse that should be checked? Other power supply diagnostics/fixes?
Prior to this trouble the printer was "unplugged" for one week. Before that it was "on standby" uninterrupted for a long time.
Thanks!
George Marton
    President:
  • 1,653 Answers
Make sure all the doors and covers are closed. If nothing happens and the FAN does not run then there are 2 fuses FU101 and FU202 on the DC controller board. Also check that rthe scanner assembly is correctly seated on the DCA Controller board.
Posted on Sep 30, 2009
My power light comes on then ngoes off immediately
1. Turn off the computer
2. Removed battery and disconnected power cord .
3. Wait, for 5-10 minutes
4. Plug the power cord back in but DO NOT reinsert the battery
5. Holding down both the Insert/Scroll button, hold the power button down for 20-30 seconds, release the power button. still hold the Insert/Scroll button press the power button normally should come up and Windows should boot.
6. Restart hit ESC it should open the BIOS and reset to default. restart computer should come back.
Feb 19, 2011 | HP Compaq Presario F500 F700 and G6000...
Tip
How to reset Canon BJC-2000 printer ?
1: Remove the Cartridge 2: Unplug the AC Power Cord
3: Close Front access panel
3: Hold down the RESUME/RESET button and plug in the AC power cord
4: Release RESUME/RESET after plugging in the AC Power cord.
5: Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET .
6: Press and HOLD RESUME/RESET for two seconds or more and release it.
7: Press and HOLD RESUME/RESET for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
This will help.Good Luck
on Mar 10, 2010 | Office Equipment & Supplies
Tip
How to reset Canon BJC-2100 printer ?
I have the Linksys Wireless-G WRT54GS Router and when i plug it into my modem, no lights come on, besides the power light which was already lit. I've tried resetting it (holding the reset button for 30...
There is another way to reset the router called hard reset..
you need to hold down the reset button for 45 seconds while its turned ON and don't let it go.
After first 15 seconds, take the power cable out but still keep holding down the reset.
After second 15 seconds, insert the power cable back in but still keep holding down reset.
After last 15 seconds, release reset and turn off the router for 30 seconds.
0-15 = Power ON, Reset button Pressed in
15-30= Power OFF, Reset still Pressed in
30-45= Power ON, Reset still Pressed in
If it still doesn't work then you got a bad router, can't be fixed. :-(
Feb 13, 2011 | Linksys Wireless-G WRT54G Router
Printer is showing "error: 0xf0af0001 Reset Power". I have unplugged and then plugged in printer multiple times and printer comes ok for about 30 seconds and then the same error message appears will all...
last month i had same problem and i contacted customer care and i got this solution. And this works.
Step 1:
Perform a partial reset.
A partial reset returns the user settings to the factory defaults. The language and country/region settings may also be deleted.
Please perform the partial reset using the following steps:
a. Unplug the power cord from the all-in-one.
b. Press and hold the "#" and 3 button on the front panel keypad.
c. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one begins to initialize.
If the issue persists, follow Step 2.
Step 2:
Perform a semi-full reset.
b. Press and hold the "#" and 6 button on the front panel keypad.
Jun 24, 2010 | HP Officejet 5610 All-In-One InkJet...
We have a Canon MP540 printer that was purchased in Aust. and it will not recognise ink cartridges for that model purchased in Singapore.
1: Remove Cartridge
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
and
1. Click on the start menu
2. Go in to Control Panel
3. Click on Printers and Faxes
4. Right click on your printer (Canon IP1600)
5. Go down to properties
6. Then click on maintenance
Step 2 - Click on ‘View Printer Status…..’
Step 3 - Click on Option
Finally, click on enable status monitor. This will turn off the monitor and allow you to use
refilled ink cartridges.
If at any time you get the ‘Ink out’ message on your PC a light under your power button on the
printer will flash. To continue printing, simply press the button and click the close button on the
warning (marked X).
You may need to do this a few times also run the printhead alginment page after.
Nov 22, 2009 | Canon PIXMA MP540 All-In-One InkJet...
How can you reset a brother HL-5170DN with out the password either with it connected via USB or ethernet i cannot remember my password
You'll need to reset your printer to factory settings. BE SURE TO PRINT A CONFIGURATION PAGE FIRST.
VIA THE PRINTER CONTROL PANEL
  1. Switch the printer off.
  2. Make sure that the front cover is closed and the power cord is plugged in
  3. Hold down the Go button as you switch the printer on. All the LEDs light up. Keep the button pressed down until the Toner LED lights. When the Toner LED lights, release the Go button.
  4. Hold down the Go button until the Yellow Status LED lights. When the status LED lights, release the Go button.
  5. When all the LED's light, the printer will start warming up. The print server has now been reset to its factory defaults.
Nov 02, 2009 | Brother HL 5170DN Laser Printer
I have an Acer Aspire one model zg5- Power cord
Here is another thing you can try. Unplug the power cord, and then remove the battery. Press the "Start" button and hold for 5 seconds. Replace the battery back into the computer and plug in the power cord. Start the machine and see if the low battery message still comes up. Sometimes the program that monitors the battery status gets confused. Doing the above should straighten it out. The Acer should start up and the AC power light should be lit. Look down in your task bar for the battery Icon or go to Battery Status in Control Panel and see if it shows that the battery is charging. Even newer batteries can go bad (rare) but if this is the case and a cell has shorted out in the battery, then your only recourse is exchange under warranty.
Jul 16, 2009 | Acer Aspire One PC Notebook
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a BJC-2100 series printer serial #FED 78237. It is giving me the following error message 5B00-Ink Waste Absorber is Full
1. Remove the Cartridge
2. Unplug the AC Power Cord
3. Close Front access panel, Hold down the RESUME/RESET button and plug in the AC power cord
4. Release RESUME/RESET after plugging in the AC Power cord.
5. Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET .
6. Press and HOLD RESUME/RESET for two seconds or more and release it.
7. Press and HOLD RESUME/RESET for two seconds or more and release it.
8. Unplug AC Power Cord to set data.
Jan 28, 2009 | Canon Office Equipment & Supplies
HP LaserJet 4L Printer Logo
167 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
