Question about Dell A920 InkJet Printer
Dell A920 Paper will not go into the printer without a jam.
Ok so I have already relined by where the input for the paper is. I have tried one at a time nothing. The paper will not go in during a print job without crinkling up and not going through.Then it will say that it's out of paper.
    Problem Solver:
  • 8 Answers
Check cartrages plz your cartrages ok after you clean pickup roller i hope your pro. solve
Posted on Mar 16, 2008
Flashing on off button printer is not communicating with computer
is a printer error, check for paper jams, and end of paper, or scanner jamed,
try reinstall printer software, may resolve these error, and reboot computer
Jan 16, 2010 | Dell A920 InkJet Printer
Dell A920 won't feed paper
just power down the printer to discharge the static electricity.. then take the paper tray out.. clean the roller and check if anything appears broken there.. if not.. lift the printer and shake it slightly.. put the power back.. check the cartridges if are correctly seated.. if yes then it should work fine.. if does not.. there's no use to take it to the repair shop you can buy a new printer in less than repair price like dell v313 for $ 59 with warranty.
Dec 20, 2009 | Dell A920 InkJet Printer
Printer only prints half of page
My printer does this when the paper isn't seated properly and/or that paper guide isn't set correctly. If this all seems OK, then try a head clean. You should be able to do this from the printer options in Windows.
Dec 13, 2009 | Dell A920 InkJet Printer
Printer will not feed paper
there could be a small paper jam or then theres a problem with the pickup but try this solution first in making sure theres no jam:
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Dell A920 InkJet Printer
Paper jam 2 - checked every area - cut equipment off and back on - still paper jam 2 - need service person asap.
there are 4 or 5 sensors through paper road:
1)paper input sensor near input roller
2)margin sensor between input roller and cartridge unit
3)transfer bell sensor between cartridge and fuser unit
4)fusing sensor before fusing
5)out put tray sensor
check all sensors if you can find out and check any paper jam there and check sensor stander at normal position, also check each sensor click ok(the micro switch ok) .
there is any sensor out of work should be showing paper jam.
Jan 23, 2009 | Dell 1600n All-In-One Laser Printer
Paper is jamming
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Dell A920 InkJet Printer
The paper is pulling to one side and not feeding properly
Mine is doing the same any help is appreciated
Jul 23, 2008 | Dell A920 InkJet Printer
HP 5180 Printer
are you using only that size paper when printing. if there's another size underneath, then you're going to see some slippage.
got fresh printer drivers?
Jan 14, 2008 | Dell A920 InkJet Printer
Dell A920
Well yes you do beacuse dell does not repair it so incase you have the warranty you can get it replaced by calling the tech. support or else take it to a local shop and they might fix it.
Dec 25, 2007 | Dell A920 InkJet Printer
Dell A920 InkJet Printer Logo
80 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
