Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi Projection TV keeps turning itself off
I can watch this TV for a few minutes and then click, it turns itself off. BUT it's not in the full off position as I must hit the power button again before it will click again to the full off position. The first click turns off the screen and sound but there is still power going somewhere because when I push the remote to turn it back on it goes to full off and when I push the power button again it comes on just to go to the suspended state. Any hints on what to look for. To me it seems like a thermal switch must be being flipped somewhere.
4 Suggested Answers
SOURCE: tvrepair
Hello my projection screen is cracked and in need to know where i can get it fixed and how much will it cost.
Posted on Dec 28, 2007
  • 927 Answers
SOURCE: Power button Flashes
Good Day, you all;
The front panel light on Hitachi TV does not really tell you much. To see what the TV is doing or better said NOT doing is remove back from the set.
If you are not a technical type person, it would be better to consult an authorized service center, but if you are perform this; 1. Remove back
2. Observe led and notice which once light, there are as many as 9 LED's.
Now that will tell you what area of the TV's circuits are to be concerned about.
Let me know, Good Luck, big IRISH.
Posted on Aug 06, 2008
  • 927 Answers
SOURCE: Hitachi Projection TV power problems
Good Day,
If TV wont turn on check Q912, Q913 & I901. If no click of relay Check Q003, als chech the Convergence IC's.
Posted on Sep 06, 2008
SOURCE: Hitachi 60v500a projection turns itself off
i have the same problem, did you ever get an answer?
Posted on Jul 01, 2009
0 characters
1 Points
I have a 1999 hitachi ultravision 60" projection tv and the power will turn on but minutes later it shuts itself off. How do I correct this problem?
When was the last time the projection lamp was replaced?The projection lamp on the tv now,has not been replaced like a 1 1/2 or 2 years,tv been on and watches like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Apr 03, 2010 | Hitachi UltraVision 60VF820 TV
Not working
Did you try to physically unplug the TV? Leave it unplugged for a few minutes then plug it back in.
Apr 03, 2010 | Hitachi 51S500 51" Rear Projection...
My hitachi tv keep turning off after 5 minuted of
I just got done putting my panasonic 50 projection back together. There is a thermal cut off relay on top of your bulb box, can normally be seen after removing the back of the tv. With the tv unplugged make sure the area around this relay is clean of dust. If the simple fix dosn't work make sure your cooling fan is coming on with the tv.
Oct 29, 2009 | Hitachi 55FX20B 55" Rear Projection...
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
The TV will turn off randomly and Not turn back on
This may help, we have a HP - DLP TV and it will do that when the bulb is going bad.
Jun 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
May 31, 2009 | Hitachi 60V500 60" Rear Projection...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
247 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
