How to connect a passive woofeer to a receiver , ain home receiver
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
Hi, I have one Samson Auro d412a active speaker plugged into the output channel of a 12 channel passive mixing board. When I sing into the mic, the speaker shuts down and the red light on the back...
If you read the TRUE specs on this speaker it is really a 200 Watt RMS unit. Make sure you are using balanced lines to the speaker XLR or TRS cables. The mixer should NOT be a passive mixer as these do NOT generate true balanced lines. Make sure the mic can't "hear" the speaker or you may be getting supersonic feedback that is above your hearing range that saturates the amp. If *********** can't stand to be ain a 15 foot square room with teh level you are generating, it is TOO loud for this unit to handle.
Aug 01, 2011 | Samson Auro D412A Speaker PA Active
Dead Samsung HTZ310
You can get your unit repaired. (cheapest option) You can hook up the speakers to another unit as long as it will work with the same impedance speakers. Don't hook them up to a receiver that is rated for 8 ohms. Your speakers are 3 ohm. The sub is a passive one, so the replacement receiver will have to work with a passive woofer.
Mar 15, 2010 | Samsung HT-Z310T Theater System
Can you program a 2003 ford key to different computer without going to dealer
It is not likely you could. The key (not the fobs) are a passive device that would not be able to receive enough power to rewrite any code within itself.
Feb 11, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Add su bwoofer to KLH 200
the subwoofer i have, a polk, connects directly to the right and left speaker lines of the klh2400.
i then connect my stereo left and stereo right speakers to the subwoofer.
essentially, the subwoofer becomes a middle station between my speakers.
make sense?
Jun 06, 2009 | KLH KL2400 Tuner
Cant install
y u cant.. just connect the speaker leads to the amplifier according to the indications including sub woofeer wire....
Aug 05, 2008 | Pioneer 1000 Watt 5.1 Surround Sound...
About technice sa-dx930
The one plug on the back of the receiver is an rca-type plug and is designed to be connected to a powered sub, which would also have an rca-type input. Even if you connected it, this output carries a line level signal and is not powerful enough to drive a speaker. If your sub has 2 connectors (same as a normal speaker) then you have an unpowered or passive subwoofer. You would either need a powered sub, or to use an external amplifier of some sort...then the sub output from your current receiver would go into the external amp...and the amp connected to the passive sub.
Hope this helps.
Mar 30, 2008 | Technics SA-DX930 Receiver
Eltax DR-110 Sub-woofer issue
Where have you connected the sub's leads?
Feb 26, 2008 | Audio Players & Recorders
Connecting a passive subwoofer!
I believe the sub output that uses a RCA plug is not amplified and wouldn't work in your case.
Nov 14, 2017 | Onkyo TX-SR502 Receiver
100 people viewed this question
 Grubhead
Grubhead
