Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
I have a poulan pro weed eater/tree trimmer.my problem started this summer when it became hard to start and would only run with the choke on and would die when I depress the throttle lever.I purchased a carb kit and spark plug,had to replace the primer bulb and fuel lines due to deterioration.Same problem after all that so I ourchased a new carburetor and it ran fine for about an hour when I shut it down.A couple days later I went to use it again and now have the same problem.I should also note I also have a new fuel cap and filter and fresh fuel.Looked in the cylinder with bore scope and it looks normal and seems to have plenty of compression.
  • 472 Answers
THE HEAD IS LOOSE TRY CKING TO SEE IF MOVES WERE IT BOLTS ON ALLSO CK THE FLY WHEEL
Posted on Sep 30, 2009
Why will My weed eater only run with the choke fully on and cant give throttle?
It sounds like the carb needs adjusted. Things can even happen to new weed eaters.
May 31, 2014 | Poulan P4500F 16-Inch Straight Shaft 25cc...
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
I have a 350 poulan pro ordered a carb. installed new filter line and primer bulk. It will start and run as long as I have the choke on. As soon as I move the lever for the choke I boggs down. Gan anyone...
Hi dennis
Sounds like to me that you have a problem with the high speed circuit of the carb...could be some trash in the jet or the jet may be out of adjustment...try adjusting the jet and try to go to full throttle after your adjustment
Apr 14, 2013 | Poulan/Weed Eater No. Te475 952711797 17"...
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
New poulan pro will not start
when I bought mine. The weed eater didn't start right away so I took it back where I bought it and I had them look over it. when reading the manuel It said that it might not start right away becuse the fuel mixture needs to be adjusted on the pro prolan pp125 weed eated. so we utilized what we had around us and found a tube. adjusted it and it started right up.
May 22, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
Sep 20, 2009 | Garden
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
588 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
