Question about Dryers
DRyer has suddenly ceased to operate. Suspect fuse
DRyer has ceased to operate. Suspect fuse may have blown but have no manual or schematic. Dryer was working yesterday
    President:
  • 1,922 Answers
Could be a fuse on the electronic control board, i take it you still have 240 volts to the unit check this also,also possible bad thermal fuse
Posted on Oct 02, 2009
My dryer does not heat up anymore
AMANA DRYER SERVICE MANUAL
Their is more than one style but mostly the components themselves all work the same as in this manual. Amana dryers are just about the easiet to repair. i suspect it is going to be the element. if it was the fuse I don't think the dryer will work if that is blown.
Sep 18, 2013 | Amana Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Hoover VHW654D-80 not heating
    see the causes, and proceed. God bless you
    Heating Element
    hermal Fuse
    Thermostat
    Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Sep 22, 2012 | Washing Machines
    Dryer stopped heating...what to do?
    Hello there
    Proper Voltage
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    Dec 08, 2010 | Dryers
    My maytag electric dryer wont heat up
    Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
    My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
    Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
    My dryer will run, but will not heat.
    Hello there
    Heating Element
    Thermal Fuse
    Thermostat
    Timer motor
    Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
    DRyer is turning just not drying clothes Maytag
    Hello there:
    Proper Voltage
    Jan 19, 2010 | Dryers
    Ariston AS66VXNA dryer - everything works but no heat- looking for a schematic to check out and troubleshoot - where can I get detailed schematic?
    You can find a manual for your model here>>>>>>>>> http://laundry.manualsonline.com/manuals/mfg/ariston/asl70c_1.html Let me ad that you may have just one side of the 240 volt circuit breaker or fuse set tripped or blown allowing all of the electronic functions, but not allowing the full 240 volts across the heating element. One way is to check the fuse box first and then proceed to measure voltage across the heating element after turning on the dryer. Please use caution while doing this. Ariston Clothes Dryer User Manual ManualsOnline com
    Jan 17, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
    Hi, My dryer suddenly stopped drying. No power to
    Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting...
    Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
    Dryers Logo
    64 people viewed this question
    Top Dryers Experts
