Question about Briggs & Stratton Garden
Fuel not getting to carberator from gas tank.
Fuel not getting to carberator.
  • 472 Answers
YOU MAY NEED NEW FULE LINE
Posted on Sep 30, 2009
John deer 175 riding mower won't pump gas to carberator. New fuel pump, can see gas in fuel filter7
could be a collapsed fuel fine from the tank. disconnect at filter and see if you can blow thru it to the tank .
Jul 10, 2016 | John Deere Garden
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
Sep 15, 2014 | Garden
Will not suck gas from tank
check fuel filter
check fuel lines
check carb diaphrams and inlet needle
Jul 08, 2014 | Husqvarna Garden
Won't start and appears to be leaking gas.
Replace connecting fuel line hose from tank to carberator or replace or repair fuel tank. Your do not start because too much air is getting into the fuel system. Seak a professional.
Nov 14, 2013 | McCulloch Quality Mcc1435a 14" Gas 35cc 2...
I just cleaned the carberator and new sparkplug it sounds like it not getting fuel when i put alittle gas in the carberator it starts and obviously stops? on my craftmen weedeater
if it is an older one, the gas lines like to rot away. you can usually tell by looking down inside the gas tank. you can also check to see if the primer is moving the fuel through the lines as you prime it
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
Is there a fuel pump cutoff switch on the 1989 ciera that can be reset or if the pump cannot be heard clicking in the tank is that the ?
fuel pump is in the tank & can be heard for 2 seconds when key is turned on. there is no
reset but by listening at gas cap you can hear if pump runs or not. spray carberator cleaner in
throtle body(carberator) to see if it helps with starting. there is a test port to check fuel pressure if you think its a fuel problem & carb cleaner helps it start
Jun 30, 2011 | 1989 Oldsmobile Cutlass Ciera
1988 chevy celebrity No fuel to the carberator.
without starting the engine position the key to the on position.
you can hear the fuel pump operationing for 4 to 6 seconds upon having the key on.
if not heard running check the fuel pump fuse, the fuel pump relay, and the engines oil pressure switch.
they all work the pump you see
the engine oil pressure switch runs the pump untill the engine reaches normal pressure
once the pressure is reached to the normal range the computer shuts that circuit off and turns the fuel pump relay on
May 22, 2010 | 1988 Chevrolet Celebrity
My tiller only starts when I pore gas into the carberator air inlet. Then it surges for a couple of seconds and cuts off
IF THE TILLER HAS BEEN SITTING A WHILE I WOULD CLEAN THE CARBERATOR SOUNDS LIKE GUM BUILD UP. I HAVE HAD LUCK WITH DRAINING ALL THE OLD GAS AND DUMPING CARB CLEANER IN THE TANK WITH GAS AND KEEP TRYING TO START SOME TIMES THE CLEANER WILL DO ITS NJOB AND CLEAN THE GUM OUT OF THE PORTS IN THE CARB
Oct 12, 2009 | Troy-Bilt Pony Garden Tiller
Honda 8HP GX240 willnot start after working fine.
Your carberator has crud, or rust, or glaze in it. The carberator will have to be removed, soaked in cleaner for three hours and then rebuilt using the proper carberator kit from any auto parts store. If you need to hire this done expect to pay about 35 dollars.
May 20, 2009 | Honda 8 HP Engine
Garden Logo
53 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
