Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice forms on the bottom of the freezer
How do I stop ice from forming on the bottom of my freezer?
  • tinel Nov 30, 2008
    we have the same issue with this freezer. The ice buids up with 5 days, then water drops out.
    Martin
I fixed mine. There is a self-defrost drain at the back of the freezer, about one third from bottom. This ices up, but ours iced and also got clogged. First I defrosted, then used a turkery baster to "shoot" one teaspoon of baking soda mixed with a cup of boiling water into the drain. In the past this is what worked. But not this time. We used 409, soap, anything else to try to unclog the drain. It took all afternoon but finally I noticed it seemed to be working. I will know in a week if the drain is actually unclogged.
Posted on Dec 31, 2007
Ice is forming on the bottom of my freezer too. I defrosted it and let is dry for 24 hours, after that it seems to be working, but now, four days later, it;s bottom is covered with ice again. What com I do?
Posted on Dec 26, 2007
  • 833 Answers
Is this a result of defrost melt liquid winding up in the bottom of the unit? Find out why it is not draining properly into the pan. A slight bit of frost is normal.
Posted on Dec 20, 2007
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
Water leaking from bottom front, ice in bottom of freezer
Your drain line form the evaporator is clogged. Locate the drain under the back and use a wet/dry vacuum to unclogged drain. The drain line can be also blocked by excessive ice buildup from incomplete defrosting. Remove frozen foods and open door to freezer section and remove power and manually defrost unit. Once ice is stopped melting try vacuuming the drain line again. Sometime drain line gets clogged with debris such as garden peas, corn, wrapping and the like. Once drain line is cleared the water and ice on the freezer bottom should stop forming.
Hope this helps
Dec 12, 2014 | Refrigerators
A sheet of ice has formed on the bottom of the freezer. Why.
There is a drain port in the behind the freezer panel where all of the water drains when your evaporator coils defrost. It has gotten clogged with food, or ice. Thaw all of the ice and unplug the drain hole, and ice will stop forming on the bottom of your freezer.
Jan 30, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Ice forming in the bottom of the freezer, not from spilled water.
you probably have a stopped up draing behind freezer wall panel
Sep 19, 2009 | Maytag Refrigerators
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
FREEZER IS FORMING ICE IN VERY BOTTOM AND CAUSING DOOR TO STICK
first of all, defrost the freezer. after that swich off your refregerator for about 8hrs and place the thermostart point on 3...............now try it. i'm sure that your problem will be solved
May 15, 2009 | Viking Professional VCBB363 Bottom Freezer...
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
Mar 18, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Jan 20, 2008 | Freezers
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
344 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
