Question about Ruud UBHC Air Conditioner
Ac keeps freezing up - Ruud UBHC Air Conditioner
  • 129 Answers
The unit is low on freon, this makes the unit work harder than its made to. I would guess around 2 to 3 pounds. You will need to call a heating and air company in your area.
Posted on Oct 01, 2009
Goodman ez-1425 ac copper pipe keeps freezing up
copper pipe freezing on the outside indicates that there is liquid evaporating in the space created by the suction of the compressor
the pipe normally will be insulated to stop atmospheric humidity condensing on the pipe
Suggest that you get in a technician to check gas pressures and ac operation
Aug 06, 2016 | Goodman Heating & Cooling
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Armana APN14K-E portable AC freezes up
Lack of air flow or a lack of refrigerant are the two primary reasons why coils freeze. Clean the filter and the coil, if frost continues it is likely low on refrigerant.
Jun 30, 2017 | Haier Amana Apn14ke-E 14 000 Btu Portable...
Dometic AC cycles on and off
sounds like you don't have enough of a charge in the system of "free-on". that would make the a/c cycle and cycle to try and keep the pressure up and would also contribute to the lines frosting and freezing
Jul 04, 2012 | Dometic Rooftop RV Air Conditioner
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
My window ac unit keeps cycling off, before it gets to the assigned temperature. Help
What may be at issue is evaporator icing. Some units cycle the compressor, others control the refrigerant to keep the evaporator temp just above freezing. If allowed to continue the evaporator would freeze over and air flow would stop....
Check and see if that is the case...
Jul 20, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
Why does my one pipe freeze when I run the ac and does not seem to cool very well
If the return line is freezing, as you describe, it typically means that you aren't getting enough air across the expansion coil, causing a large block of ice to build up inside.
Once that happens, you'll always get ice on the return line.
Try cleaning the filter or whatever the AC uses to keep the air clean.
Feb 25, 2011 | Samsung Heating & Cooling
My AC keeps freezing. Condenser pipes freezes all the time and the repair men just keeps adding freon. What is the problem?
Hello MCOMSTI You have a freon leak that MUST be found & repiared so the system will keep the charge.A fast leak is eaiser to find,look for a oil/grease stain anywhere on the system,when you loose 1/2 system charge you make ice.
Aug 05, 2010 | Goodman CLQ30AR32 Air Conditioner
Ruud UBHC Air Conditioner Logo
70 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
