Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Poulan wild thing leaf blower won`t start. Has
Poulan wild thing leaf blower won`t start. Has spark... plug gets wet.. no start. Scored piston? Only used one season. Changed gas...makes weak attempt at starting.
  • Anonymous Mar 17, 2014
    poulan wild thing leaf blower starts but imediately shuts off
    Problem Solver:
  • 19 Answers
If you used an incorrect fuel mixture you have a stuck piston ring which is giving you low compression. These units are extremely fuel mixture sensitive...too much oil causes carbon buildup, cylinder scoring and stuck piston ring. Take off the muffler and use a small pick to push on the piston ring...you should get some movement. If not ring is stuck. You may be able to see scoring as well.
Posted on Jul 16, 2013
  • 472 Answers
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
Weed eater fb25 won't start
This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
Jan 18, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My weedeater leaf blower never gets up to its' old speed. Runs about 1/2 the power. Tried a new spark plug and air filter. New gas didn't help.
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 11, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My craftsman leaf blower will not start.
Basics to check:
b) is there spark
1) spark plug
Remove Carburetor
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
I'm unable to start the engine.It won't even kick over.
Most likely you have low compression caused by stuck piston ring or a scored piston and cylinder. This unit was made by Poulan and
they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the
new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
Your cylinder could also just be worn out. This blower has a fairly short engine life.
Sep 21, 2009 | Poulan Featherlite Gas Blower, with Low...
Poulan leaf blower bv1850 Runs greate for about 30 seconds, then dies. Replaced fuel lines and installed carb kit. No better. Adjusted the one adjustment screw out 1-1/2 turns out for starting position....
Most likely low compression caused by stuck piston rings or a scored piston and cylinder. This unit was made by Poulan and they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
Sep 20, 2009 | Garden
I have a Craftsman Blower/Vac model 358.794770 that won't start. I'm not getting any spark from the plug when I pull the rope. I've replaced the plug, ignition module and the wiring harness but it still...
Sep 12, 2009 | Craftsman Garden
Poulan/Weed Eater No. Bvm200le kills when taking it off choke or giving it gas.
You might also need to rebuild the carb.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
40 CC WILD THING POULAN
Generally, these saws are set at the factory and aren't supposed to be adjusted. If you can remember how far you turned each screw I would suggest you turn it back to where it was. Turning the screws clockwise leans out the mixture and although it would seem to make it run better warm, it is too lean to start properly. If the engine doesn't start at the factory setting you probably need to take the carb apart and clean it and put a new kit in it.
Oct 02, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
1,941 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
