Question about Neff 24 in. S5456 Built-in Dishwasher
My 3-4 yrs old Neff washing machine is leaking from the bottom especially at the very right front corner,also it appears that the whole bottom sheet is logged with water & rusted! can you help please
  • 234 Answers
One of 2 problems: either the water level sensor is burdened with deposits and not stopping the water fill in time (that is: it is allowing too much water in) and the extra water drips out the door bottom which is not a sealed opening, or the gasket around the door is distorted or brittle or encrusted with deposits that do not allow a sight seal along the sides of the door and the jets inside are forcing water past the gasket.
Your manual should show you the water level sensor and how to avoid deposits the will affect it. The manual may also direct you to the gasket poor seal problem, but this is pretty-much a visual thing. Good luck, Macgivor
Posted on Oct 04, 2009
Lg intellowasher 7kg wd8074fhb
The water pump can be a source of a leak.
Oct 29, 2013 | Washing Machines
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
Water leaking from front right corner - not hoses
The leak is coming from the area of the drain pump, but you will need to remove the lower toe panel directly below the door to sufficiently inspect where the leak may be coming from. The access screws are located under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. The following link explains what to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Make sure you check all hose connections on the drain pump and make sure the drain pump reservior cap (if equipped) is on tight. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Apr 05, 2010 | Kenmore HE2 Plus Front Load Washer
Leaking westinghouse 9.5kg washing machine
a hose has partially come off or a cut in the hose
Sep 06, 2009 | Westinghouse Washing Machines
Our whirlpool is leaking from the bottom during
our door gasket was leaking and running out the bottom... not sure how the gasket got holes in it but it had five or six holes and it is not that old. the gasked was over a hundred dollars and the water bill ran over a hundred dollars before I found the leak
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
Jan 18, 2009 | Neff W5340X0 Washer
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Leaking water
Maybe it leaks from te heating element. Happends often on older Candy machines!
Jan 22, 2008 | Candy AQ130 Front Load Washer
Neff 24 in. S5456 Built-in Dishwasher Logo
221 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
