Question about Maytag Dryers
The belt fell off the dryer how does it go on
  • 304 Answers
The belt usually comes off the rollers if you turn the drum by hand. The link below will show you the belt configuration for most Maytag models. Maytag machines are made in several configurations.
Dryer belt configurations
Posted on Oct 01, 2009
When I push the start itll start but then right away it stops
If your dryer only runs when you hold the start button in, you probably have a broken dryer belt or it came off inside. There is a belt safety switch near the motor that if the belt comes off or breaks, it won't let the dryer run. There are 2 screws in the top lip of the door area that the door would close against facing up into the dryer top. Remove the screws and lift the top up. If you don't see a skinny black belt around the drum, it broke and fell down inside.
Apr 06, 2015 | GE DVL223GB Gas Dryer
My white knight tumble dryer drum has stopped going round and the dryer is just making a loud humming noise, please can you advise?
Your belt probably broke or fell off the motor . The humming noise is the motor running without a belt on it
Jul 15, 2011 | Dryers
A belt fell off in my dryer and idk where it goes
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 21, 2011 | Whirlpool Dryers
My gas dryer will not turn the clothes drum
The drive belt that turns the drum has broken off or fell off. Sears does sells these belts in a kit forn including the tensioner pulley. Purchase that. The top and front panel will need to come off to do this repair
Jul 11, 2010 | Kenmore 62602 Electric Dryer
Kenmore 62084 electric dryer belt fell off i need directions on how to get it back on
Good day,
I'll include a link that shows you how, however, there is usually a cause for the belt doing that.
You should make a close inspection of the belt, as well as all the bearings. You can check the rear bearings, by lifting the drum out.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Jan 17, 2010 | Kenmore Dryers
Belt tension part. it fell off and i need to know where it goes on the dryer. Kenmore 80 series gas dryer.
The bracket goes into holes on the floor beneath the motor pulley and looks like the picture of whirlpool in the link below when properly mounted:
http://www.applianceaid.com/images/belt-config.JPG
Oct 29, 2009 | Kenmore 62602 Electric Dryer
Pulley fell off while reassembling kenmore dryer 80 series
the pulley goes right beside the motor pulley,the belt goes under the big pulley and onto the motor pulley-mike
Mar 03, 2009 | Kenmore 659 Electric Dryer
Putting dryer belt back on
The piece you see is called the idler pulley. Here's a link to a good description of how to change a dryer belt. It should show you what you need to do set it all right.
http://repair2000.com/wpoolbelt.htm
Nov 26, 2008 | Kenmore 62872 Electric Dryer
Lost sheet in Dryer
BUY THE TIME YOU PUT THE MONEY IN IT FOR THE PARTS AND THE HEAD ACHE YOU MAY WANT TO CONSIDER BUYING A USED DRYER THE COST MAY OVER WEIGHT THE MEENS
Oct 04, 2008 | Kenmore 75944 Gas Dryer
Screw fell out of pocket between drum and inerds...
dnkmett, the dryer actually comes apart from the rear. Remove the rear top section, remove the 28 screws holding the rear panel, unhook the belt and remove the assy. When putting it back together be sure to reset the broken belt switch after putting the belt back on. That switch is on the motor beside the idler pulley.
Jul 17, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
79 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
