Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
I want to know if an ' N ' range wireless router s
I want to know if an ' N ' range wireless router is compatible with my pc. which is 3 yrs old and has wireless capabilities, as had a belkin 'G' router connected but kept 'dropping out' . i am starting to use the net more and use remote log in to use the office computer more & more.
many thanks,
Bharat
  • Gateway Master
  • 3,289 Answers
All of the "N" routers I have seen are backward compatible to the 54 Mb "G" standard. An "N" router on your network will mot likely not work any better than the old "G" router did (unless there was something wrong with it) if you continue to use the old "G" card in the PC.
To take advantage of the greater range and other technical advances that the "N" router offers, an "N" card should used in the PC, too.
To maximize speed and reliability of any wireless "G" network, decrease as much a s possible, the distance between the "G" router and wireless PC.
An open air, "line of sight" path is best. A path through gypsum board, wood, foil backed insulation, brick, concrete, steel goes from "OK" to "very difficult". Basically, the thickness and type of material can affect the signal. The harder it is for you to drill through the material - so is the difficulty of passing a wireless signal through (more or less).
Minimize interference by reducing or removing any cordless 2.4 Ghz telephones, intercoms, etc. These devices *can* significantly reduce the range of wireless G networks. Try it yourself by unplugging the base and removing the battery from a handset to see if this is a source of interference for your location.
Posted on Sep 30, 2009
I put in a high speed motom and now my router has a weak signal. other devices in the same room can only get a weak signal or no signal.
1-Is it a cable modem? The new ones Cox has out are DOCSIS-3 and if your router is several years old you may want to replace it with a router that is designed for DOCSIS-3. I kept my DICSIS-2 router (3 yrs old).
2-You should do a few speed tests to confirm performance then talk to your internet provider about your connection. I had to have Cox come out to check things and they replaced a component on their side.
3-Do have a friend or a neighbor going through the same thing? I did, we compared notes and got to the bottom of it.
Good Luck
Nov 09, 2013 | Airnet AWR014G8 Wireless Router
II have been trying to connect wirelessly my new HP lap top to an old series 600 but the computer can't connect even after entering the key. It works ok on cable.can any one help
1. your issue is due to a a wireless laptop is not compatible with the old router or
you may need a firmware upgrade.
2. the cold compute may be able to connect via a cord (Ethernet) but not wirelessly due to an outdated driver for the network card ( the card will need updated drivers also) if it is a wireless b card then the ability to us a WAP key will not be possible
because your card was designed to use WEP key.
3. a new wireless G card installed to the old PC will allow connectivity if the wireless card is backwards compatible.
4. most all PC's can connect via a Ethernet cord they are all designed that way and have not changed for the 20 or 30 years they have been in use.
I hope this helps. Have a great day!
Oct 05, 2010 | Zyxel P660HW-D1 Router
Have a Wierless-G router can not install, tried 3 times. While installing it has very limited range , pc is 4-5 feet away & couldnt pick it up. Any ideas ???
check the wireless settings of the router. try to change the channel of the wireless network.
SSID broadcast should be enabld on the router. It depends on the computer also.
If your router is old then upgrade the firmware of the router. firmware is the software of your router.
Click here for more information about the router
Mar 27, 2010 | Linksys Wireless-G Broadband Router
Connecting sitecom range extender to dlink router
you can get a wireless booster that is compatible for dlink router. you can visit this website. http://www.altex.com/%2FD-Link-RangeBooster-G-Wireless-Router-WBR-2310-P143286.aspx
Mar 24, 2010 | Computers & Internet
Can I boost signal strength?
You will need to get hold of a Belkin Wireless G Universal Range Extender relays the signals of your wireless network and extends its range model number F5D7132 from PC world or another online dealer.
You will still need the wireless router as the central connection point, using the booster your network now reaches further I have one at the top of the stairs with the Router downstairs to I can browser wirelessly in the loft conversion of my old house
Oct 11, 2009 | NetGear DG834G Wireless Router
Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
Sep 29, 2009 | NetGear DGN2000-100NAS Router
Need usb wireless card for pc
Any brand should compatible with your Westtell, as long they have same range of frequency (i.e 2.4 GHz, 5.8 GHz), etc...
I will recommend 3Com, Linksys and D-Link.
P.S.: If this information was helpful, please rate this solution.
Mar 23, 2009 | Westell Wirespeed VersaLink...
Trouble creating wireless access point from D-Link DI-514 router
1. Connect a pc to the router using a cable (wireless won't work)
2. Open a browser and type in: 192.168.0.1
3. Login with username: admin password: (blank)
4. Browse around the menus until you find a setting similar to "use as access point" and select it.
5. Save settings and log out.
6. Connect a cable from a port on your main router to this router's internet/wan port.
Dec 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G Broadband Router can't connect to the internet suddenly.
hit reset button on it unplug modem and roiuter for wile cool down run cleaner son pc make sure no bugs use superantispyware free edition get bugs out that will driop u ok after all that still dont work get netgear new oen 29 at best buy ok easy plug in play they only last 3 4 yrs anyways ok
Oct 06, 2008 | Linksys Wireless-G Broadband Router
Broadband router range
If you have wireless N router. You should install wireless N adapter on your children's computers as well. That way, they are compatible with each other coz I guess your children's PC has wireless G adapters. You wont be able to utilize the N signal of the router if your using wireless adapters..
May 15, 2008 | Computers & Internet
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
