Question about GE Refrigerators
Gasket were replaced but still leaks water - GE Refrigerators
    Scholar:
  • 103 Answers
If leaking out front of door on freezer, then you have a drain plug that is stopped up or frozen. Drain plug is located in freezer, underneath evap coil, when unit goes into defrost mode, if drain is plugged up, water has no where to go except out thru doors.
Posted on Oct 01, 2009
Does a water pump gasket problem lead to other gasket problems- such as intake or head gaskets/ and is it associated with having coolant loss issues?
If the low coolant from the water pump leaking has caused the engine to overheat, then the cylinder head(s) can warp and the head gasket(s) will leak also.
Feb 04, 2015 | Cars & Trucks
How do I repair a leak coming from water pump gasket?
If it's leaking from the gasket you'll have to replace the gasket. If coolant is leaking from the hole in the water pump body the water pump seal is leaking. The pump will have to be replaced if the seal is leaking.
Sep 12, 2013 | 1999 Plymouth Voyager
Oil leak from head gasket can it be replaced
For leaking head gasket it has to be replaced.For head gasket leaking and other troubleshooting,there are help links provided.Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------Water in engine oil? http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
-----------How to replace head gasket on car? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket? http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century? http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
http://schematicsdiagram.blogspot.com/2011/12/location-of-head-gasket-on-1994-grand.html
HOW TO REPLACE A HEAD GASKET
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-head-gasket.html
How to replace Exhaust Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-exhaust-manifold-on.html
How to replace Intake Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-intake-manifold-on-acura.html
How to replace Cylinder Head ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cylinder-head-on-acura.html
Is it Easy to replace head gasket?
http://schematicsdiagram.blogspot.com/2011/12/is-it-easy-to-replace-head-gasket-on.html
Should I only replace head gaskets or complete head gasket assembly? http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html --------Troubleshoot Car Oil leak? http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
---------Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket? http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
---------This will help.Thanks.
Jan 30, 2012 | 2006 Scion tC
-----------How to replace head gasket on car?http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket?http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century?http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
Should I only replace head gaskets or complete head gasket assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html --------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Car oil leaks from valve cover gasket?http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Antifreeze leaking for bottom bolt of water pump, do you think it could only be a gasket ?
It could be a gasket, but more likely bolt thread sealing issues. Get some teflon tape, pull the bolt, wrap it and reinstall it. Pressure test to see if you stopped the leak.
A bolt will typically have metal all around what it holds, and usually gasket leaks happen between bolts..
Feb 24, 2011 | 2001 Dodge Dakota
My 1996 chevy suburban wont start
If you plugged the original leak (which sounds like the head gasket) and then the radiator was leaking, and you are having water coming out of the exhaust, then you need to replace the head gaskets. It sounds like you had a blown head gasket from the start. Here's what to do.
1. Replace the head gaskets (will need intake manifold gasket as it need to come off for this procedure).
2. Replace thermostat, radiator cap (if radiator is still good)
3. Replace water pump; the water pump may have stopped working (mechanical), which in turn caused the pressure to build an blow the head gasket (the cause of the pump would be a bad thermostat. If the truck was overheating, then the thermostat was bad to begin with, then the pump, then the head gasket, so then the only place left for the water to go is out the exhaust.
Here is a list of replacements:
^ water pump
^ thermostat
^ head gaskets
^ valve cover gaskets
^ radiator cap (if radiator is good)
^ radiator : if leak from cap caused any damage to radiator (should still be good)
**Also check the radiator hoses to ensure they do not have any "bubbles". Hot water over time (with anti-freeze) erodes the inside of the hoses, and begins to "dig" holes and grooves in the hose, which evetually cause leaks. Consider replacing these as well for safe measure.
Please, let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 22, 2010 | 1996 Chevrolet Suburban
Ascaso Dream Leaking Water
Correct, inside the grouphead their is a gasket which is the same diameter as the filterholter which make the perfect fit so the presure of the water will not leak out. So now either the gasket is damage in one point so you have the leak from that point. Second the gasket have become hard so it can not make perfect fit with filter holder. In both above case you have to replace the gasket. Finally their is aposibility that the gasket is dirty with coffee remains and again we can not have a perfect fit. You can use a hard brash with the water running so you can clean the gasket.
With this case you can unsrew also the shower from the grouphead and clean it also for better coffe results
May 05, 2010 | Ascaso Dream Espresso Machine
2000 old intrique using alot of water/coolant and
If steam is coming out of the exhaust it is probably the head gasket. I take it you are adding a lot of water so you have a big leak or a blown gasket. Check to see if water is getting in the oil, another sign of gasket leak.
Jan 06, 2010 | 2000 Oldsmobile Intrigue
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
