Question about Nikon D80 Digital Camera with 18-135mm Lens
Same problem. Err inn the upper left corner. No other messages. No flash popup. Just the sound when I click. But no pic.
  • 149 Answers
Problem in mirror loading replace or repair it
Posted on Oct 04, 2009
How can I change what font is the default font in Microsoft Word?
In Word 2007, locate the Font toolbar in the upper left area. In the very lower right corner of the Font Box, there is an expansion arrow. Click this arrow and note the FONT popup screen. Here, choose the font you want to be default, then click the DEFAULT box in the lower left corner of the popup screen. Answer YES to the question about changing the font on all Normal Template documents.
Jul 12, 2016 | Microsoft Office Word 2007 Upgrade Version...
How to disable popups blocker
In the upper-left corner of your screen, you will an Apple icon. Just to the right of that Apple, you might see the word "Safari". If you do, than click on that word, "Safari", and a menu will drop down. Select "Block Pop-up Windows" from that menu, then release. If it was checked, that will uncheck it. Select it again to check it. Now you are in control! Enjoy!
Sep 05, 2014 | Apple Customized 15" MacBook Pro Laptop...
Allow popups in chrome
When you use Chrome and a popup comes up but it gets blocked.. You will see a small RED x in the upper right corner of your screen in the address bar. Click on the red X and you will see some options for that blocked popup. Choose "Always accept popups from that site". Reload the page and the popup should work fine after that.
Dec 31, 2013 | Computers & Internet
Red Light Indicator Flashing??
There is an old message stuck in memory. Hold down the OFF button on the base handset for 10 seconds.
Dec 02, 2009 | Uniden DECT 6.0 Cordless Phone ID
When I try to take the pic the #5" comes on and flashes at the upper left hand corner. I tried turning the camera off and it still is flasing. I turned the camera off then opened the door to the CF card...
If you hear a click and then get Error #5 then either the flash is not popping up as it should or the two little switches under the flash are stuck. Gently help the flash up, then turn the camera off and on again to clear the error message. I found the hinge on my flash was corroded, probably due to getting sea water in it. Hope that helps.
Sep 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon eso err 05 how do I fix it ?
This means a flash problem.
The reasons for it may be several ones. Let me go from the one with higher probability to the lower one.
1. Flash is stuck. It is the most comon reason, and more easiest to confirm. When pressed the shutter (or pressed the flash side button in P mode) you hears a repetetive click noise, and the flash won't pop up. If this happens, the flash is stuck.
Sometimes is solved when at the same time you press the shutter button, with the finger (or nail) you gently pull it up. Once is up, check for dirty, or any residues (such as tape glue, sand or something like that) that stucks the flash.
Some persons apply a thin layer of lubricant on the side hinges. Don't put so much lubricant or oil because will get inside the camera, and cause other problems.
2. If not click sound is heard, the either the flash actuator relay or the DC/DC board (that provides power to the flash board) or the flash board are defective. This can be confirmed only in a camera repair shop.
If you need further support, please let me know.
Best regards,
Jul 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Texas Instrument TI-83 Plus error message ERR:MEMORY and the number keys won't work
Hit the "2nd" button in the upper left hand corner of the keypad, and then the "+" button (lower right hand corner). Then either click the down arrow once and then "enter" or just hit the "2" button. (the selection should say "2: Mem Mgmt/Del...") Hit Enter again (selecting the "1: All..." selection) Scroll through the programs on her calculator and either hit the "Del" button (upper right hand corner of the keypad) to delete the programs/variables, or hit "ENTER" to archive them. The archived programs have an asterisk, " * ", in front of them. (Note: Once you delete the programs, you CAN NOT get them back) If you have variables on there "L1" "A" etc. you can delete them and use them again later, obviously.
You can bypass this whole thing and just do "2nd" "+" "7". This combination will reset the calculator and delete any programs that are unimportant to the calculator. You will be left with the "Finance..." option in the APPS menu only...nothing else. You should be able to clear up the problem either way.
Apr 26, 2009 | Office Equipment & Supplies
Can't open attachments
in your internet the popup for attachments is blockd it means new window it wil open so it can be showd in left down corner to get your pop up window your attachemnts can be shown
Apr 13, 2009 | Yahoo Mail
Nikon D80 Digital Camera with 18-135mm Lens Logo
151 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
