Question about JBL 4´´ Gulf Slip Tip for 5/16´´ Shaft 6 mm - Spearguns - Speargun/Hunt
Does 6mm come before 5/16 - JBL 4´´ Gulf Slip Tip for 5/16´´ Shaft 6 mm - Spearguns - Speargun/Hunt
    President:
  • 1,653 Answers
5/16" is equivalent to 0.3125 inches
6 mm is equvalent to 0.23622 inches
Posted on Sep 30, 2009
I have a Ryobi R-151 router with an 8mm collet, I cannot find and router bits with 8mm shanks, is their a 6mm collet, or adaptor available for this model? Regards Pete
There are 8mm to 6mm adapter sleeves available. If you take the collet along to a power tool store they may be able to supply you with a suitable 6mm collet. I can't find what type of collet is in the router, but I'm betting it is a ER-11 type in that size range.
https://www.maritool.com/images/ER11-Collet-1.jpg
Nov 23, 2016 | Ryobi Tools & Hardware - Others
Hood latch missing a nut, what size of nut is needed?
6mm?
measure it , ? (other nut or the hole there)
and if 6mm , it is?
use a ruler?
6mm is about 0.236" inches
here is a list of ISO standard sizes (metric)
6mm pitch 1 is common. (course)
https://en.wikipedia.org/wiki/ISO_metric_screw_thread
as are other sizes.
or go to jeep and buy one?????
Aug 14, 2015 | 1999 Jeep Grand Cherokee Limited
I need to know ignition timing on a1945 wdco 350 royal enfield 5,16 btdc more or less
TDC should put piston 1 to its highest position with valves closed (compression). 5.16 BTDC if you don't have the markings on the flywheel and the engine block, you should make them anywhere and use them as reference markings. Hope it helps.
Oct 15, 2014 | Enfield Motorcycles
Does anyone know what size the oil pan bolts are for a 2001 CR-V ?
what engine, of the many?
take one off, measure it. bingo.
(usa) 0.236" is 6mm
outside USA, 6mm measures, 6mm (bliss)
next is length ( 12mm or 15, or , measure it.)
and last is pitch. (not like USA TPS at all )
i have a $1 pitch gauge, sold, well ,everywhere .
or got to ACE hardware (usa)and use their gauge.
or test your screw against there marked nuts. (simple)
easy huh.
old post but, the only one, like it ,so , i answered for all searchers.
Aug 12, 2013 | 2001 Honda CR-V
Logbase16xtopower5=logbase64 125-logbase4rootx soveforx
Type solve(log(x^5,16)-log(125,64)+log(x^(1/2),4),x,0.5
Its equation with guess 0,5. Then press enter and you will give result
x=5^(1/3)=1.70997
Or, you can use equation solver with eqn=0(MATH, then B option)
See captured images below
Feb 26, 2013 | Texas Instruments TI-83 Plus Calculator
How do I clear a HK 30 6mm bb
Try this website:
http://www.ehow.com/how_6530030_unload-p30-air-soft-gun.html
Jan 20, 2013 | Umarex H&k P30 - Black .6mm Bb
How do i change a fuel pump of a honda accord 1996
need to disconnect negative battery cable remove fuel filler cap then you need to relief fuel pressure by using box end wrench 6mm you need to loosen 6mm service bolt at top of fuel filter need hold bango bolt with another wrench.use shop rag when loosen 6mm bango bolt to catch the fuel. you have to drop fuel tank but you need to disconnect fuel pump electrical connector in the trunk,remove 2 way valve cover fuel hose protector, then diswconnect fuel lines.
Sep 29, 2012 | 1996 Honda Accord
How do you work out 3/5ths of a cm
6mm
1/10 = 1mm
2/10 = 2mm
1/5 = 2mm
so 3/5 = 6mm
May 11, 2011 | Computers & Internet
Do i need 6mm or 10 mm cable to connect 4.2 kw oven
6mm twin and earth is more than enough for your oven.
Feb 15, 2011 | Ovens
How do i put on a new fan belt on a 2000 golf tdi?
Well for the fan belt its really simple: You need: a 13mm Socket, a 6mm Hex bit, and a ratchet, a large crescent wrench would also be helpful.
1. Loosen the 6mm bolt that holds the alternator in.
2. Loosen off the 13mm bolt that is on the bracket.
3. Take the old belt off.
4. Put on the new belt.
5. Slightly tighten the 13mm bolt, and use the crescent wrench to tighten the belt (using the half gear/half nut tightening assembly)
6. Tighten the 13mm.
7. Tighten the 6mm.
Sep 28, 2009 | 2000 Volkswagen Golf
JBL 4´´ Gulf Slip Tip for 5/16´´ Shaft 6 mm - Spearguns - Speargun/Hunt Logo
Top JBL Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a JBL Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
