Question about HP Laser Jet Printer P3005dn
Manual Tray feed is only printing skewed- everything was fine - toner cartridge was really running out and we had no new one so we change the cartridge for a used one with some toner left. I was send two pages from the manual tray, realized I did not want to print on that paper and pulled it out just before it grabbed. However, it did say "paper jam." Now whenever I put any paper into the manual tray it is printing skewed- tipped to the left. Any ideas how to fix? I tried cleaning - powering down and back up - nothing seems to work. I'm thinking its tied to that dumb paper grab on my part.
  • HP Expert
  • 222 Answers
Clean paper pick up roller whit wet cloth or alcohol, clean registartion assy check paper path for small pieces of paper or something... good luck
Posted on Oct 01, 2009
Testimonial: " Helpful and quick - but I still have the problem - is there anyway it's cartridge related?"
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
How do you eliminate a line going through each page
Run a 1/2 print test.
Put paper in the manual feed tray (tray 1).
Print something. When the paper feeds 1/2 way into the printer, open the top cover.
Remove the toner cartridge and look down at the paper. If you see the line, replace the toner.
If there is no line, then the problem is probably the fuser.
Feb 13, 2011 | HP Laserjet P3015X Printer
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
Lexmark E332n- Changed toner cartridge and now off alignment How do you cartridge align
It is fairly common in this model for the paper size guides in the paper tray to shift outwards, allowing the paper to skew feed as it is being fed into the printer,
Pull out your paper tray, and make sure the adjustable paper guides on the left and right sides of the tray fit up snugly to the paper in the tray.
try this, good luck.
Dec 16, 2009 | Lexmark E332n Laser Printer
I have a HP LaserJet 1320tn, after I changed the cartridge I keep getting paper jams just about where the paper meets the cartridge
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
Jun 29, 2009 | HP LaserJet 1320 Printer
Print fragmented documnts
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 14, 2008 | OKI MICROLINE ML-395 Matrix Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Printer Printing Crooked!
try printing from the multi purpose tray...do you get the same problem...if not you can narrow the problem down to the paper tray area...try changing main pickup roller and separation pad. If problem is present printing from either tray then the next place I would go is to the registration assembly (flapped unit that resides under the toner cartridge). The job of the part is to line the paper up before it feeds further in to the printing process. You could also do whats called a 1/2 test...put paper in the mp tray, do a print and when there is only about 2-3 inches of the paper sticking out the mp tray open the toner lid...lift out the toner cartridge and see if paper is skewed before entering the fuser. It really does sound like the registration assembly.
Inkworks
Apr 24, 2008 | HP LaserJet 2100 Printer
HP Laser Jet Printer P3005dn Logo
112 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
