Question about Adesso PCK-308UB (DHPCK308UB) Keyboard
Some keys (buttons) do not work, some do. Here is the alphabet, from a to z, from the keyboard- bcghmntvxyz. Key pad-- 123456 (789 don't work) Any insights would be welcome!
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Hi!! Some of the keys on my keyboard is not working! Sometimes they do, sometimes they don't!!1 HELP
open your keyboard and cleans the key pad keys . If you using your keyboard more then 2 years its better to change it
Jun 17, 2011 | MSI Computers & Internet
Iwant to be ablleto balance check book usig the right side calculator pad
try the combination of
Fn Key and NumLock Key (both Fn and NumLock will be of a diff colour on the Key board) and you will have the numeric key pad available
and the same function again after your work will unlock the nummeric key pad also
hope could be of help
Mar 28, 2011 | Dell 0Y3740 Keyboard
Fault with alphabetical/numerical keypad
unplug and replug the keyboard
if that doesnot work replace the keyboard
Feb 12, 2010 | Computers & Internet
Key button got pluged off
You probably broke a little tab that connects the letter to the actual button.
Just get some of that thick (foam) double sided tape. regular double sided tape wont work.
good luck
May 20, 2009 | Acer NSK8458AN Keyboard
Fn key wont turn off
OK, I've found a soliution! :) I've been diging the internet and many people are having the same problem, so it is a common problem however the soliution is very simple (in my case). The thing is that laptops does not has a saparated Num Pad, and numbers can be found on keys under F1-F12 row or/and (active with Fn key) on alphabetic keys uiopjkl;m/ and so on. But if there is a NumLk key on your keyboard, you can lock the Num Pad on alphabetic keys. Then you have to hold Fn key pressed to write letters.  Find the NumLk key and try to turn off the Num Pad :)
On my laptop (Acer extensa 5120) NumLk key is on F11 and active when Fn is depressed.
Hope this wil help :)
Oct 01, 2008 | Acer Aspire 5100 Notebook
I need help in understanding the keyboard functions
dear,
what does it mean. do you want to know the hotkeys of just want to speed up your typing speed.
if you mean is to speed up you typing speed. then use softwares like typing tutor etc. i used typing tutor 6. it is an old version but is simple too. now i can type very fastly.
or if you want hotkeys then visit this links:
http://users.sa.chariot.net.au/~kday/keyboardtips.html
http://www.helpwithpcs.com/tipsandtricks/keyboard_shortcuts_microsoft_word.htm
http://wiki.blender.org/index.php/Manual/Hotkeys/Hotkey_Keyboard_Map,
the last one is impressive.
regards,
salman
Jul 22, 2008 | Computers & Internet
KEY PAD OF LAPTOP
This link may help:
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
Dont forget a fixya rating if this solution helped :)
May 11, 2008 | Dell Inspiron 630M Notebook
KEYBOARD PROBLEM
The number lock is engaged on your laptop keyboard. usually that is FN+F11 keys or number lock is on by default in the BIOS setup.
Check and see which F1-F12 key looks like a number pad
Mar 19, 2008 | HP Pavilion dv2000t Notebook
S510 Keyboard
ya same problem here too. i fixed the problem by buying a non logitec keyboard
Mar 16, 2008 | Logitech Cordless Desktop S 510
Adesso PCK-308UB (DHPCK308UB) Keyboard Logo
108 people viewed this question
Top Adesso Computers & Internet Experts
Alun Cox
Pcm2048
Chris Benedict
Level 1 Expert
Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
