My Dell keeps crashing so I want to format and start again but it wants an administrator password. As far as i know i haven't set one so i can't go any further. I've tried to guess it but it says my account has been disabled. Any help appreciated.
If the system is asking for an administrator password in Windows and you are wanting to format and reinstall the system, then the password shouldn't be an issue. Most inspiron systems are equipped with a PC Restore partition CTRL+F11 just after the Dell Splash Screen should enable the restore process. If PC Restore doesn't work, then boot to the XP CD and format the NTFS partition and install Windows XP clean. If you have Windows Vista, the PC Restore is run from the F8 Boot menu. If no restore partition is accessible in Vista, then again Boot to the Vista DVD and format the NTFS partition and install VIsta.
When plugged to AC it charges the battery normally if the laptop is not operational.When you power...
(More)
When plugged to AC it charges the battery normally if the laptop is not operational.When you power up the laptop it stops charging and runs on battery and goes off when the battery runs down. If you remove the battery and power it on AC,the power LED blinks but the laptop does bot come on HP nx9110
No video on local or remote display. When powered on it looks like everything else is comming up...
(More)
No video on local or remote display. When powered on it looks like everything else is comming up just no video on the LCD or on a monitor hooked to the video out connector.
