Question about Sony Playstation 3 (PS3) Console
Yellow light - Sony Playstation 3 (PS3) Console
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 122 Answers
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Posted on Jul 24, 2010
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Tail light wire colors
Hi Anonymous,
Black=Ground
Red=Brake light
Yellow=Tail light
Have nice day.
Jun 24, 2013 | Harley Davidson Motorcycles
What is the yellow flashing light
In the cross-sections, when there is a yellow flashing light "a driver may proceed through the intersection or past the signal only with caution."
Mar 21, 2013 | iBuyPower Gamer Computers & Internet
What is the color code for replacing the light switch on a '94 Marquis with factory alarm and keyless entry?
Here you go. I think this may be what you are looking for. I hope this helps and good luck.
1994 Mercury Grand Marquis Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Yellow Ignition Switch Harness Starter White/Pink Ignition Switch Harness Ignition Red/Light Green Ignition Switch Harness Accessory Gray/Yellow Ignition Switch Harness Tach Gray/Orange EDIS Module Brake Switch Light Green Brake Switch Trunk Release Purple/Yellow Driver's Kick Panel Trunk Pin Brown/White (-) Light in Trunk Parking Lights Brown Light Switch Head Lamp Red/Yellow Light Switch Hood Pin n/a Factory Disarm n/a Door Trigger Black/Light Blue Driver's Kick Panel Door Lock Pink/Yellow Behind Glove Compartment w/Keyless w/o Keyless (-) Door Unlock Pink/Light Green W/o Keyless Reverse Polarity Horn Wire Yellow/Light Green (-) Steering Column Windows Up LF=Yellow, RF=White/Yellow, Windows Down LF=White/BlackRF=Tan/Light Blue
Mar 26, 2011 | 1994 Mercury Grand Marquis
Took out drum, and yellow cartridge to release jam, cannot get yellow back in
On the topmost part of the printer, there are four buttons in the following order (top to bottom): Black, Cyan, Magenta, and Yellow.
Besides the four button is another button with 4 dots (Black, Cyan, Magenta, and Yellow with a rotating arrow), press this once and you will see that the Yellow button on the left will light up, press it again and the light besides Magenta will light up and so on. Anyway, you get the idea.
Just keep on pressing it until the light besides Yellow lights up again. When it does, lift the top cover of your printer and insert the yellow toner.
Jun 03, 2010 | HP LaserJet 2550L Printer
When i turn on my PS3 it as it starts up a yellow light comes on
Apr 16, 2010 | Sony PlayStation 3 40GB System
3 red lights and yellow power supply light
at the very least the main board is acting flaky with the 3 red lights flashing. Here is tutorial courtesy of LLAMA to show how to resolve that problem:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
As far as the yellow light on the power supply is concerned. Unhook it from the Xbox 360 and only plug it into a power outlet. If the light is yellow then the power supply is bad. If the light stays green then plug it into the xbox 360, if it tells yellow then, at that point you know that the main board is causing the yellow light on the power supply and that means the main board is bad.
Aug 03, 2009 | Microsoft Xbox 360 Console
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
My Dell Monitor isn't working....yellow light?
A yellow light indicates no signal input. Test it on another machine.
Feb 16, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
