Question about Kettler Mondeo Elliptical Trainer
I have no idea where you power this machine up for programming. It was given because of a move. How does the programming work? Batteries?
  • 85 Answers
According to the manual its powered by an A/C adapter,
http://www.ifitnessdirect.com/pdf/kettler/mondeo.pdf
You can get a universal one from radio shack that should work.
Posted on Oct 03, 2009
My casio cash register was off power and had no baterries, now the feed works only can you help
If you have batteries in it now, take them out. Turn key to REG mode. Leave it unplugged from power for about 30 minutes. Plug into power and it should initialise. Put batteries in it once it comes back to life. Re-program the machine
Jan 08, 2016 | Retail Supplies
Casio se s2000 not printing
You must never remove the batteries without leaving the power turned on. The register will lose all programming if you do this. Error 4 normally means all program lost, ready for new program. The printing may have stopped due to this. If it still has batteries, you might be able to recover the memory by following the instructions under 'clearing a machine lockup' near the end of your manual. If you have lost the manual, one of the users has one here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S2000_users_and_programming_manual.html
Aug 10, 2014 | Casio Cash Register
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
I have a nordictrack audiostrider 800 that i just replaced the console. now the resistance won't work. thoughts?
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
  1. Replace the Batteries
    • 1 Replace the batteries first, if your machine has batteries. A manual machine such as the NordicTrack MTN 740 will not need batteries, and instead the console is powered by your moving the steps. Check your manual if you are unsure of which batteries to buy. Different machines will require different batteries. The NordicTrack Mini Stepper uses watch batteries, but larger machines will likely need AA or D batteries.
    • 2 Take off the cover to the battery compartment. Remove and discard the old batteries. Replace all of the batteries, not just one if you happen to have one good one. Align them correctly with the "+" and "-" signs as shown on the compartment.
    • 3 Replace the battery cover and attempt to turn on the console.
    Reset the Circuit Breaker
    • 1 Check the circuit breaker. A machine such as the NordicTrack CXT 990 will have a circuit breaker located on the front of the machine. The console will not work if the circuit breaker is tripped.
    • 2 Push the circuit breaker in if it protrudes until it sticks.
    • 3 Try to turn on the console. Check the circuit breaker for your house if this does not fix the console problem.
    Adjust the Reed Switch
    • 1 Inspect the reed switch as the information on the display will not be true if the reed switch is too far from the flywheel on NordicTrack machines such as the MTN 740.
    • 2 Unscrew the two M10 by 82mm button bolts on the right pedal bracket. Unscrew the two M10 nylon locknuts. Pull off the pedal bracket and set aside.
    • 3 Remove the two M4 by 38mm screws. Remove the three M4 by 25mm screws. Slide the right side shield off to expose the flywheel, magnet reed switch.
    • 4 Unscrew the screw that holds the reed switch in place but do not remove it. Slide the reed switch toward the flywheel but leave enough space that the magnet can move freely. Replace the shield and bracket
Oct 19, 2011 | Nordic Track NordicTrack Treadmill, A2550
Motors won't turn
Are the batteries FRESH? if they are you may have a bad motor. Contact Meade customer service:
http://www.meade.com/support/index.html
It sounds like BAD batteries. Try new ones first before sending it to Meade.
May 15, 2010 | Meade 114EQDH4 (36 x 114mm) Telescope
Won't work after replacing batteries
sounds like the batteries might be in backwards. Please remove the batteries and then put them back in insuring that they go in correctly.
Oct 30, 2009 | Computers & Internet
I was given a new light blue Gaggia 'Francis Francis' machine ten years ago. I used it pretty regularly, then put it away during several house moves . I'm trying to get it working again now, after 5...
valve in group head seized. remove 'shower' under group head with central screw remove internal spring loaded jet clean and re-install. Then run a de-scale.
Sep 19, 2009 | Coffee Makers & Espresso Machines
There is no power
Seems like you are on the right track and you can save alot of money there. I would aproach this systematically trace the power to the switch then t0o the speed controller and back to moter you can also put some jumpers from a battery to the moter connections.
If it is in such new condition then it must be a damaged or loose connection.
Jan 21, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Kettler Mondeo Elliptical Trainer Logo
675 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
