Ricoh Aficio AP3800C Laser Printer
Problem for Ricoh Aficio AP3800C Laser Printer
I have serious color shifting occuring even after
By totalfor875 on Sep 30, 2009
I have serious color shifting occuring even after manuel color registration. Lots of clicking noises that I can't isolate. I have a new transfer unit on the way. Is there any way to run the main motor in service mode, with PCU's & developers removed so that I can isolate the clicking noises? I want to make sure I don't have any stripped gears.
Best Solution
posted on Oct 03, 2009
Very Helpful)
quickfix4u
Rank: Guru
Rating: 86%, 26 votes
No,the printer will not run without PCU's installed.The only way unfortunately on this model is to check all gears visually.Most likely bad gears either in one of the PCU's or in the fusing unit.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Found the problem. The toner waste auger within the magenta PCU broke off the spindle. Replace the PCU and repaired the broken auger. " - totalfor875
Popular Solutions for Ricoh Aficio AP3800C Laser
Questions and Unsolved Problems for Ricoh Aficio AP3800C Laser
Do you recommend Ricoh Aficio AP3800C Laser Printer?
Answer
Answer
how do i install wireless ricoh africio ap38000c pcl 5c
Answer
The soft buttons wont react when I am in Scanner mode, Printer and Copy modes work fine.
Answer
i have a savin c3030 and its giving me the error code sc400. what it is?
Answer
Each time I try to print from WordPerfect to the printer, I must set the paper size to 8.5 x 11. For... (More)
Answer
Hi I've got an Ricoh Aficio CL3800 which has started printing black marks (small dots) each dot is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio AP3800C Laser...:
Top Printer Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
