Question about Sharp AR-M205 Copier
I get error 7 when scanning.
I have a problem when scanning devices come up.
It just says "A machine error has occurred. Please check the machine". On the machine I have E7. Any ideas?
    Sniper:
  • 54 Answers
Error is probably E7-11 Push the start button to see the last two digits. E7-11 is the copier white balance error when using the document feeder. Either the white sheet on the bottom of the doc feeder that rides on the small strip of glass on the right side, or the optics are dirty. Clean either with windex sprayed on a soft cotton rag or paper towel. If this does not fix the problem, then you may need a new MCU circuit board.
Please don't forget to rate all answers please.
Posted on Dec 20, 2007
Hp 3500C communication error
Restart the PC and the scanner and try again. Make sure you installed the right drivers, make sure that the PC see's the scanner, check devise MGR and look under printers, interface devise.
Apr 03, 2013 | HP ScanJet 3500C Flatbed Scanner
Scanjet 4890 prepared to scan, but will not work
Uninstall the Driver Software, switch off the Computer and reinstall the driver software again. This should work.
S. Mohan
Oct 12, 2009 | HP Scanjet 4890
HP J5780 - Using scanner with print server
no, print server is just that, print server is only good for printing. I don't know if there are a device you can use for all-in -one office machine. I am looking for one myself.
May 29, 2009 | HP Officejet J5780 All-In-One InkJet...
Hp officejet 7310 all-in-one software will not install
  1. Solution one: Make sure the hardware is functioning correctly(try to make a copy)
  2. Solution two: Restart both the All-in-One and the computer
    3. Solution three: Check if the correct scanning device is selected as default under HP Software
    4. Solution four: Download and run the Scan Diagnostic utility(FROM HP.COM)
    5. Solution five : Check that the Digital Imaging Monitor is running
    6. Solution five :Try scanning without HP Imaging software
    7.Solution six :Try scanning without HP Imaging software
Jan 26, 2009 | HP PSC 1410v All-in-One Printer
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Sharp AR-M205 Copier Logo
444 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
