Question about Jensen KA3 Car Audio Amplifier
How many watts is it? - Jensen KA3 Car Audio Amplifier
    President:
  • 1,653 Answers
KA3 offers 125 watts RMS at 4 ohms, 200 watts RMS at 2 ohms, and 250 watts at 1 ohm. The high-current section offers 50 and 75 watts RMS at 4 and 2 ohms, respectively
Posted on Sep 30, 2009
  • lonewolf1010
    lonewolf1010 Mar 16, 2013
    it has 2 speaker out puts and a sub output can u tell me the watt output on each
On a ceiling fan with a watt limiter .. should I still have approximately 120 volts at the bulbs if watt limiter is working correctly ?? Or does the watt limiter also reduce voltage ?
It depends on how the limiter works. Watts = volts x amps. Reducing either volts or amps will reduce watts. Best way to answer your question is with a voltmeter. Take a reading in a bulb socket when powered on and watt limiter set to maximum watts. Then take a reading with the watt limiter set at 50% [half].
Mar 26, 2016 | Dryers
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Does Malibu still make a model number ML500TW timer transformer
Intermatic/ Malibu series lights are available 44 watt, 88 watt, 100 watt, 121 watt, 200 watt, 300 watt, 600 watt, 900 watt.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
None of the other brands sells 500 watt either.
Kichler sells 300 and 600 and 900Watts
Paradise does not have 500 watt
Malibu brand does not carry 500 watt
Portfolio does not carry 500 watt
Apr 16, 2013 | Hardware & Accessories
How many 5 watt outside lights can you power with a 20 amp breaker?
Volts x amps= watts.
20 amp breaker x 125 volts = 2500 watts.
However, electrician use the 80% rule, so multiply 2500 x 80% = 2000 watts.
So if you have 20 amp breaker, and 12 gauge wire, and 20 amp switch, and distance is less than 150 feet, then watt load is 2000 watts or 400 5-watt bulbs.
Keep in mind that most switches are 15 amp, and not 20 amp.
Recalculate for 15 amp switch = 1875 watts x 80% = 1500 watts or 300 5-watt bulbs.
Jun 22, 2012 | Home
What kind of speaker watts should be ok to marantz pm74d?..i want to know to make the sounds make better...
Hi,to know what watts to use for marantz pm74d, first you will need to know the watts of marantz pm74d for you to be able to know the watts of the speaker you will want to use for marantz pm74d.
You make sure the watts of the marantz pm74d you want to use for the speakers are not bigger the watt of the marantz pm74d,
eg, marantz pm74d----150 watts
speakers depending on the numbers of speakers your using 60 watts.
So if you are using one speaker of 60 watts and your using more than one, add all speaker watts and divide the speaker watts by the marantz pm74d watts, the weight on the marantz pm74d will be too much to handle too much speakers.
Make sure the marantz pm74d watts is high enough to carry the speaker you want to use.It helps you determine the quality of sound you want to hear..
Thanks for using fixya........
Jan 06, 2011 | Audio Players & Recorders
How many watts would you get from a generator rated at 11hp and 5.8 kva. thanks
kva = kilo-volt-amps
watts = volts x amps = va
Therefore, 5.8kva = 5800 watts
Mar 24, 2010 | Honda 3000 Watt Portable Generator
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
Sep 16, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
Technical Question
A: Running watts are the continuous watts needed to keep items running. Starting watts, are extra watts needed for two or three seconds to start motor-driven products like a refrigerator or AC unit.
Aug 27, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Jensen KA3 Car Audio Amplifier Logo
291 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
