Question about Jenn-Air JED8430 Electric Cooktop
Replacing RF burner dual inf. switch on Jen-Air JED8430 electric ceramic cooktop. Replacement sw. does not match up to the original. What is the wiring sequence on the new one? In numerical order on the old sw., 1. yellow, 2.white, 3.compound black,, 5.compound red, New sw. sequence from top, clockwise, p1, 2, p2, s1, s2, 4a, 4 This sw. was a repalcement from AP Wagner. Thanks if you can help. Thanks if you can't.
3 Suggested Answers
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
  • 491 Answers
SOURCE: I am installing a Jenn Air JED8430 electric
Posted on Nov 08, 2009
Why are lights not working under the ceramic JennAir stove top?
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Apr 27, 2014 | Jenn-Air JED8430 Electric Cooktop
How do I replace a broken dual infinite switch on my Amana AKT3040SS ceramic cooktop?
raise cook top out of counter and remove screws holding glass top to base . remove glass and on the right is switch bank two screws holding each / remove and do not pull wires. but transfer one at a time noting that markings on old sw match new . . sw pt # is 12002125 and cost 49.35. and reinstall in reverse.. hope this helps . and do turn off the power before you start. mm good sailing .,
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Front double burner not working on Jenn Air ceramic cooktop model # JES8750AAB
mostly the problem is the sensor inside the unit but so very expensive to replace,wait to damage the other then buy an new one compare to repair.
tnx gerbee
Jun 29, 2009 | Jenn-Air JED8430 Electric Cooktop
I cannot REPLACEMENT KNOBS fOR model # 5D02
This company has your knobs.
May 23, 2009 | Jenn-Air JED8430 Electric Cooktop
Wire for stove top burners
same place you got the switches,you can usually get the whole harness.
Nov 17, 2008 | Jenn-Air JED8430 Electric Cooktop
Tripping breaker
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at - search using the cooktop model number). To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity.
Sep 20, 2008 | Jenn-Air JED8430 Electric Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. back
Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
178 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
