Washing machine the hose that goes from the washing machine into the pipe that runs the water away outside i can see the water coming back up the pipe that the hose goes down how can i unblock this?
  • 2 more comments
  • smirf Dec 21, 2007
    sorry i dont have a garden hose.anything else i could try?
    sorry for being a pest i typical woman.What tool called or what do i ask for?do i buy a coupling too plus the other tool as well.
    will give it a go when i buy tools i in scotland so have to wait till they open thanks.
  • Anonymous Mar 21, 2014
    Will machine come on if water pipes are off
    Sergeant:
    Champion:
  • 262 Answers
There is a tool that hooks to you garden hose that goes in your pipe and expands then blows water down the drain to blow out stoppage it work great you can get it at your local hardware store
Posted on Dec 20, 2007
  • Bill Dozier Dec 21, 2007
    Ok try this same tool but but a coupling to go from the tool to your washer hose it will do the same thing and probably better because of more pressure this WILL work ive done it a million time and keep it on my service van at all time it a life saver just make sure you get the one for 1 1/4" to 2" I think it is
    yes you have to buy the coupling too it not about $3.00 the tool is a rubber piece about 6"long and has a female thread like on a garden hose I cant remember the real name off hand and what I call it you can put it on this site not a nice word but the tool is in the drain cleaning tool isle you can miss it the rubber is black and the connector is gold you take the hose off your washer put coupling on hose then tool on coupling push the tool all the way in to your pipe and turn on water.HOLD THE HOSE IN THE PIPE IT WILL BLOW OUT before it expands
While using washing machine water leaks out
sounds like the lower pipe or pump pipe is leaking or come away. you need to pull the washer out and place it on its side (left as you look at front) and check the pipes on the bottom, they have pincer clamps on the pipes, if the pipes are cracked or damaged replace them but usually its just they have come loose from drum movement. and just need fitting back on. also the drain pipe needs to be at least 3 inches from the top level with the water in pipes height of the washer so the water does not just come out.
Jan 13, 2018 | Washing Machines
Water is not getting into the washing machine. Fridgidaire Crown series. Water is coming through the hoses. Detatched hose from washer, water still comes out. Cleaned screen on back of washer. No...
Hi. sounds like the pressure system is blocked if it goes through a cycle with no water. Find the pressure switch in the top of the machine its the size of a small coffee jar lid, it has wires and a thin rubber pipe to it, pull the pipe off and see if the switch clicks as you do so. If it does you need to follow the pipe, at the end it goes to the pressure chamber.It will be blocked with gunge and will need cleaning out, also blow through the pipe to make sure thats clear. Make sure you fit the pipe back with no air leaks or the machine will over fill and flood.If you don't feel confident in doing this Please call an engineer.Best to be safe, it could also have damaged the heater or thermal cutout
Regards Elect App
Jul 14, 2011 | Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Started washer and as water filling, it was coming out of the soap dispenser onto the floor..what is wrong?
run hot hot water only turn off and on if water is coming out of the soap dispenser onto the floor this will help clean it try it first worked for me
Oct 14, 2009 | Kenmore HE2 Plus Front Load Washer
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
My Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Apr 19, 2009 | Indesit W 123 Front Load Washer
Washing machine drain hose/pipe leak
Make the standpipe longer (the black pipe).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 01, 2009 | Washing Machines
Leak from pipe/wahing machine drain hose
try running the snake from the top to the bottom. they ell pressure hose ends that you inser into the pipe on the end of a hose and when you turn the water on it weslls and applies pressure to push out whatever is in there. they cost about 8.00 and you can buy them at lowes or home depot. just tell them what you need and that it screws onto the end of a hose for unclogging backed up drains. im not sure whats its called but they will know
Feb 01, 2009 | Estate TAWX700JQ Top Load Washer
My new Front Loading washing machine has a terrible mildew problem!!!! I have used clorox bleach, lisol, clorox spray cleaner and the problem goes away for one load. If a new load sits for more than 30...
your drain where the hose drain hooks to your house isnt draining fast enough ,there must be lint in the pipe ,when your washing machine pumps out the water the pump shuts off ,but the drain hose is syphoning the water that the drain pipe has in the pipe back into the machine
Jul 08, 2008 | Whirlpool Washing Machines
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
