Question about HP LaserJet 1320 Printer
Printer is chewing/ripping/creasing paper. - HP LaserJet 1320 Printer
    President:
  • 1,653 Answers
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Also check the rear panel and make sure that all the guides and rollers are moveable and not distorted in any way.
Also check the paper pick up for wear as this will cause additional pages to be collected and fed through the printer. Make sure that you fan the paper before use ant it is of suitable quality and weight.
Posted on Sep 30, 2009
Crease in paper when printing
Your information is a bit limited but we'll try anyway.
If the crease is a corner fold or a pressure line down the page, it will often be caused by something in the paper feed path close to the main drive bar in an inkjet or near the fuser in a laser printer. Have a look at the leading edge of the paper as it exits the printer for a nick or mark that may give a clue where to start looking. If there is a fold or crumple line down the length of the page, look at the paper pick up mechanism in an inkjet (usually the paper tray is a good start) or if it is a laser printer you should remove the fuser and check the fuser sleeve and pressure rollers. If you could let me know what the machine is and where the crease is I may be able to give better advice.
Jul 09, 2015 | Office Equipment & Supplies
How to disassemble a Kodak ESP C110 printer?
Hello Edward,
There really is no reason to take it apart fully as the printer is showing classic signs of a paper jam. Usually it is a small piece of paper that has torn off and is lodged in the printer's paper path, it also could be something small such as a paper clip. Yours obviously is located on the side that the crease appears. The paper feeds in and then it hits the stuck object, then jams. Look very carefully at the leading edge of the paper near the crease and it may show the exact location of the foreign object. in the paper path. Remove the object and you should be all set!
Good Luck!
Rich Lilja
Mar 01, 2015 | Kodak Office Equipment & Supplies
Paper creases
I have the same problem with my printer.??????????
Feb 18, 2014 | Samsung SCX Office Equipment & Supplies
The printer creases the paper top left hand corner
hi just check the inside one paper gear will be if it is creases measn that is problem
Dec 16, 2010 | HP LaserJet 1300n Printer
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
Kyocera FS - 3900DN creases the paper
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
May 28, 2010 | Kyocera FS-3900 DTN MONO LASER PRINTER
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper is printing but top edge of paper is creased and torn
It sounds like your maintenance kit is defective.
The excess oil leads me to believe that.
Jun 04, 2008 | Xerox Phaser 8200 Laser Printer
Appears to be a roller crease on the paper
i want the installation cd fo my printer HP PSC 1410
Jan 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
Printed paper is creased
First thing to check is try it with a fresh unopened ream of quality paper, paper with too much moisture content, drys out and goes wavy when it runs threw the fuser roller at rear (180 deg), otherwise it will be the fuser rollers themselves causing your problem, which means that you need to replace fuser assy
Dec 05, 2007 | Samsung CLP 300 Laser Printer
HP LaserJet 1320 Printer Logo
299 people viewed this question
Seeker5211
Seeker5211
