Question about Philips SA2310 GoGear Mp3 Player
I disconnected my mp3 and its says " player problem,connect player to PC, format Player" and i connected it back and it dosin't turn on.
    President:
  • 803 Answers
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Sep 30, 2009
Thomson 6677
Hello Ace,
Is it possible that you are looking in the wrong folder in the MP3 player when it's disconnected?
Kind regards,
Ron.
Mar 27, 2014 | Audio Players & Recorders
Can't make the player turn on. What do I do?
First try and reset the player.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not work try this,
Remove the battery - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
STEP 1 - Connect the device to the computer
1. Remove the battery from the player's battery compartment.
2. Put the hold/lock switch to lock.
3. Plug in your device to the computer.
STEP 2 - Format the device
1. Double-click My Computer.
2. Right-click on the player, which might show up as a Removable Drive, select Format.
3. Click Start.
4. Click OK when a "Format Complete" dialog appears.
5. Click Close.
Nov 12, 2010 | SanDisk Sansa m240 MP3 Player
My sandisk e250 sansa mp3 player does not boot. shows only SanDisk logo. My computer also do not detect the player as new hardware.
  1. Turn off player.
  2. Slide HOLD button to locked position (towards headphone jack).
  3. Press and hold RECORD while connecting to the PC.
  4. Release RECORD when you see "welcome to recovery mode" on the player's LCD.
  5. Open My Computer/Windows Explorer and see if you can find a new removable flash drive labeled "16MB-FORMAT".
  6. Right click on 16MB-FORMAT and select New Folder.
  7. Name the new folder "sansa.fmt" (without the quotes).
  8. Wait one minute.
  9. Reset HOLD back to unlocked position.
  10. Disconnect player from PC.
  11. Wait for player to reboot.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
I have the same problem.
this time you are reformatting that player, i think that connection between is malfunction...
Jun 16, 2009 | Sony NWZB133F MP3 Player
REPAIR MP3?
Hello - doesn't anyone listen. Connect the player to your computer, and open the Philips Device Manager, and run a repair.
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Nov 26, 2008 | Philips GoGear SA3125/37 MP3 Player
DMP400N
Since I was unable to turn my Mp3 player off, it eventually ran out of battery!
I then connected it to my pc, and now it seems to work like a charm!
Jul 31, 2008 | Audio Players & Recorders
Hey
It is easier to reformat the mp3 player. When the mp3 is plugged in to the PC, go to my computer, the double click the mp3 player there. You will see internal storage, right click that and click format. You will lose all the stuff on the mp3 player.
Oct 26, 2007 | RCA Lyra RD2765 MP3 Player
Player does not play
Hi, I had the same problem, MiMusic wouldn`t even recognise there was a disk connected although I could see it in My Computer.Found the answer on internet.
Attach it to your p.c. Then go to My Computer and highlight it. Right Click it and a box will appear . Go to FORMAT and format it. Another box will appear and ask if you really want to do it as data will be lost. Answer YES. Then format it. Disconnect from your p.c. Turn it on and you will be able to access the menu facility. Follow the instructions and goto CREATE LIB, BEFORE you put any music on to the thing.
I found it created library as soon as I disconnected it. BACK UP anything you have on it first as it will be wiped. It is working perfectly now and MiMusic is too. Yippee. Pat.
Jul 07, 2007 | Goodmans GMP33000S MP3 Player
WHEN I AM CONNECTING TO MY PC IT IS GETTING ON AND OFF
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Feb 17, 2007 | Transcend T.sonic 610 MP3 Player
My mp3 won't turn on!!
Sorry, as far as i know you can't, you nead to reset: 1. Recharge the product by connecting to the pc (pc must be running). 2. Press the reset button using a sharp tool. Wait 10 minutes then connect the player and pc. (The reset button is between the FUNC and MODE buttons.) 3. Turn the player off and press the mode button while making the player and pc connection. 4. The message ¡°USB Connected¡± displays when turning the player on. 5. Disconnect the player and pc. 6. Connect the player and pc after turning off the player. The player is charged in about 2 hours if the player is off. 7. Upgrade to the latest firmware (Ver. 1.11 or higher).
Nov 14, 2005 | Mpio FG200 MP3 Player
Philips SA2310 GoGear Mp3 Player Logo
89 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
