Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
While trying to tune in my le32r7 tv..I find that I can't select the tuning option as the cursor keeps by passing it..What can TI do?
  • 6 Answers
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
Are you recording something ? if so wait for it to finish or stop it and you should be able to access it afterwards
Posted on Sep 30, 2009
How do i select the channel menu
Many times the re-scan tune option goes away if you've selected an input on the TV other than the "tuner", "Antenna" or similar (ie: AV1, HDMI1, Sat, Cable, etc.do not make use of your TV's internal tuner).
Make sure you select an input on your TV, ( tuner, etc.) that will use the tuner and have an antenna or non-digital Cable TV coaxial cable connected. Then attempt to scan again.
Dec 15, 2014 | Televison & Video
What buttons do I use to auto tune my soniq tv 42"
There won't be a direct button to Auto Tune. That would be too risky. What happens if you accidentally press it halfway through an important program.
The tuning and other set up functions are accessed via the TV menus. There's probably a button called something like Menu or Setup. Once you press that you'll see all the options. Use the navigation and OK/Select/Enter key and the Exit/Back key for navigation.
Somewhere in your TVs menus there will be a section for tuning. Within that there will be at least two options - Manual Tuning and Auto Tuning.
Hope this helps.
Sep 18, 2014 | Televison & Video
I have tried to tune my tv but its still not going even when i put the cable in the right place.! it just shows no channels at all.! what can i do?
In your "Channels" menu, you should have the option of "auto tune". Once you've plugged in your antenna, cable cord, select this option. Before doing so, unplug your tv ONLY and let it set for about a minute. Plug it back in, turn on, go into Channel Menu and select the "auto tune" option. This may take a while, as newer tvs have several hundred channels. This will auto tune your tv to the channels received through your selected device\cable. You may consult your user manual for further assistance. I just did this with my tv a couple weeks ago and its very simple. You will also be able to "delete" channels that do not come in well, or not at all i.e. The "ant screen" etc.
Aug 29, 2014 | Televison & Video
I AM USING SONY EX710 LED TV EVERY TIME IT SHOWS AUTO TUNING ?
go to menu(remote control) then select tuning option keep Auto tuning Off.
thank you
Feb 20, 2011 | Televison & Video
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
I have a quasar tv and Z remote how do i program it to my tv?
Tune the TV with the remote control provided with device
1. Power on the TV by pressing momentarily the power button
2.Select the menu option on the programs list on the remote
3.Using the navigation arrows to locate the channel options
4.The option of tune also indicated as auto tune is the function to select to program the TV
5.A press on the auto tune button would initaite a scan through the entire TV functionality,
6.The process should tune the TV in which time would acquire available signals either broadcasts or devices that have been connected to the TV would be recogsied as well.
7. Any TV broadcast signal would be stored in the TV memory making possible program broadcast after process is achieved.
Important note
The TV would only capture signals on subscription to broadcaster establishment. For example, after TV tune up, no shows available requires acquiring service from providers. Examples of which include Dish Network, Time Warner Cable, or Digital Subscriber stations for possible broadcast subscriptions
Dec 02, 2010 | Televison & Video
TELEVISION
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
Oct 01, 2009 | Televison & Video
Cannot tune in programmes I go to menu which brings up screen picture, audio, time but skips on tuning into progs and goes to options. Please help.
Select TV as input source by TV remote or push Channel button on remote then go to TV Menu. That will enable Tuning menu in TV.
Jul 28, 2009 | Televison & Video
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
457 people viewed this question
Jerry Greenberg
Jerry Greenberg
