Question about Logitech ClearChat Stereo Headset Headset
When making a call on skype, problem says no recording device
When i go to recording devices, i've none shown
have surfed, but can't find any software drivers for this ClearChat
am running on Vista 34bit
thanks, ash
3 Suggested Answers
  • 263 Answers
SOURCE: Computer used to recognize my Logitech Clearchat
Try microsoft hotfix..
Posted on Aug 02, 2009
SOURCE: ClearChat Pro USB headset asks for driver upon install
  1. (Vista) Confirm your system restore point first. It needs to be prior to what you're going to attempt here. If it has a recent restore point, great, but if not, make a system restore before you do this, in case it doesn't work.
  2. In the Control Panel, click System, Advanced System Settings, click System Protection, and click System Restore.
  3. (Optional) Try updating your usb drivers before trying the final step, reinstalling the Vista Service Pack 2.
  4. Here's how to verify if your USB (drivers) in the Device Manager are up to date.
  5. Open the Control Panel, System, Device Manager.
  6. Open the Universal Serial Bus controllers (usually at the bottom of the device list).
  7. Right-click, on your first USB, Updating Driver Software. It will look for the update or let you know (which may take a bit of time) that it is up to date already. Repeat this process on all the USB devices.
  8. If that doesn't work, try this: plug in your headset, and keep it plugged into the usb.
  9. In your Windows Updates, re-install the Service Pack 2. After Vista reboots your computer and finishes the install, unplug your headset from the USB and then replug it in. What you are likely to see is a Windows message indicating that it sees the software and is installing it (minus the windows pop-up message of "where's the driver disc for it?").
  10. Now the trick is to get the headset to play the microphone through the speakers appropriately!
Posted on Oct 21, 2009
  • 16 Answers
SOURCE: Logitech ClearChatStyle Headset + Skype + Vista Premium Home
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
Posted on Aug 07, 2010
0 characters
1 Points
Blue tooth wireless mic stops recording after 8 minutes
don't know what program you are using to make the recording(s) with, but have you checked to make sure that the program is set to record more than 7-8 mins of speech? (some programs, like youtube, etc only allow about 10 mins recording for certain formats)
or that there may not be enough memory allocated for the program / file format being used?
Mar 06, 2012 | Headsets
Skype not working
Click this link for more information........
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Can hear but no one can hear me on Motorola H721 blue tooth
GO TO setting - control panel -open sound and audio device -open audio -go to sound recording and make shore your head set is listed in default device -open volume and increase the volume if needed - close every thing open skype and do a test on your head set by opening the test service
I hope this helps
Oct 29, 2011 | Headsets
I have my plantronics discovery 975 paired to my computer and my phone. It is supposed to automatically connect when I skype and it doesn't. When it is connected it only lasts for less than a minute...
  1. Make sure you are using the latest version of Skype.
  2. Make sure that Bluetooth works on your computer. You can refer to your computer manufacturer's documentation or website for details on how to set up Bluetooth on your computer. You want to ensure that the Bluetooth software and drivers (known as the Bluetooth stack) on your computer supports the Headset Profile (HSP). It's recommended that you download and install the latest drivers for your Bluetooth stack.
  3. Pair your Bluetooth device with your computer. How you do this will depend on both the Bluetooth stack on your computer, and the Bluetooth device you are using.
  4. Make the Bluetooth device your Skype audio device:
  • Sign in to Skype and in the Tools menu, select Options...
  • Under Audio settings, select your Bluetooth device from the Microphone, Speakers and Ringing drop-down list.
  • Remember that not all Bluetooth headset features may be available when making a call with Skype. For example, whether the buttons on your headset function correctly depends on your Bluetooth stack.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Discovery 975 (8164001 P)...
I have just set up skype on my laptop and tried using the echo /sound test. Though my mic seems to be working I do no hear anything. I have checked the sound settings and skype does play sounds through my...
If you are running Windows 7 you can have audio set up to listen to the mic. I would not recommend this though as there is a slight delay from you talking to it coming out of the headphone. This can cause you to stumble on your words. But solely for testing purposes do this if you use Windows 7:
1. RIght click on the speaker icon in the lower right corner of your display and select recording devices.
2. Make sure the microphone you use is highlighted blue then click properties button in lower right corner of the window.
3. Click on the listen tab, then check the box that says listen to this device.wdaexodus.png
Mar 05, 2011 | Cyber Acoustics AC-201 Consumer Headset
Is h350 compatible with windows vista? i try installing one, i easily paired it with my compaq laptop windows vista os without asking any passkey. the problem is it would'nt work. i downloaded a bluetooth...
I've successfully paired this headset with Vista but only for Skype. In Control Panel set the Bluetooth discovery and it should pair OK but then you need to run Skype which will find the headset and ask if you want to use it. The solution is a bit temperamental because the microphone volume is usually either low or there is too much background noise.
Feb 01, 2011 | Motorola Mobility H350 Wireless Headset
I have problem in plantronics dsp 400..regarding mike..i cab hear the incoming calls but i cant hav any conversation in mike..the end user cannot kindly rectify this it would be of...
<span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: navy; FONT-SIZE: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">The first thing you need to check is your audio settings and make sure that both sound recording and playback are set to the same device. If you
Aug 19, 2010 | Plantronics DSP-400 Headset
I have purchased a BW900 headset and and trying use the headset on my PC for skype. I have a bluetooth dongle and the PC recognises the headset, however on the bluetooth devices list it has a...
in windows xp!!!
click start
all programs
volume control
click devices
recording devices
check the box for your default device..
Vista / Windows 7
right click the speaker icon to the bottom right of your screen (tl bar)
click recording devices.
click set as default,, you may also adjust and set up the device..
Mar 16, 2010 | Sennheiser BW900 Bluetooth Headset
People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
Jun 15, 2009 | Logitech 250 Headset
Logitech Microphone Not working
Hi, I have a skype approved logitech headset. I can hear sound, but I cannot record sound or communicate on it. I cannot even find the headset as option as Preffered Device in Sound and Multimedia. I am using Windowsxp
z. Please help.
Feb 21, 2008 | Logitech (980174) Headset
Logitech ClearChat Stereo Headset Headset Logo
338 people viewed this question
Top Logitech Headsets Experts
Brian Sullivan
Brian Sullivan
Richard Roberts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Logitech Headset Expert? Answer questions, earn points and help others
