Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
it has stopped makeing ice. It still has water at the outlet but its not getting water to the ice...
(More)
it has stopped makeing ice. It still has water at the outlet but its not getting water to the ice maker. There seems to be a valve at the bottom in the back. Could that be the problem?
My fridge isn't staying cold and my freezer has ice built up in the back of it, but the food in the...
(More)
My fridge isn't staying cold and my freezer has ice built up in the back of it, but the food in the door and my ice cream are defrosting.
I have a Kenmore model 106.57282791 side by side and the freezer is not working right.It gets chilly...
(More)
I have a Kenmore model 106.57282791 side by side and the freezer is not working right.It gets chilly but not enough to freeze.The coils are frosted only on the bottom 2 coils and up the right side. What can I do?
Kenmore 57029 Side by Side Refrigerator side not getting adequate air flow. Is this controlled by...
(More)
Kenmore 57029 Side by Side Refrigerator side not getting adequate air flow. Is this controlled by mechanical linkage to difuser or a thermally activated valve or a combination of both?
