Question about Welding Tools
LEARNING TO WELD by someone that knows what they are doing
LEARNING TO WELD i 58 years old needs to brush up on my welding would like to have a master that might be retired that would help me get back on track. Oceanside Vista are the areas that I would like I have credentials so that you will know that I am not some nut, I am very serious I really need the help and I want to be taught by someone that really knows what they are doing I would make it very easy on for you once a week at your convenience maybe twice a week but I figure in a month I could pretty much learn the fundamentals and go on with what I want to do so please take this serious and e-mail me I want to get started right now
my name is Ron
  • 71 Answers
Hi there Ron this is Frank i am a 6g certified welder i have been welding for about 19 years,from stick to tig to mig im not sure where your from but it would take me less then a month to teach you looking forward to hearing back from you.... thanks frank
Posted on Nov 07, 2009
HOW DO I GET THE BOLT ON THE FIREWALL OFF IF IT IS TACKED ON WITH A WELD?
why do you want to remove . the new one need to be held down also . but grinders work real well
Dec 11, 2015 | 1993 Ford Escort 4 Door
Sandpro 50 4510 water is squirting out of the front and it appears to be a hairline fracture. how can I fix this as it isn't even 2 years old?
JB Weld. Make sure the surface (inside and outside) and the crack is clean and dry. Mix up some JB Weld and press it into the crack from both the inside and the outside. Be sure to spread a layer of JB Weld across the crack. You do not want the JB Weld to be just in the crack.
Let the JB Weld cure according to the package before reassembling and running water through it. I would give it a whole day if possible.
OR
If the crack is just on the tank itself, you can find just the tank online for around $50.
Here is one place i foound...
http://www.brandsonsale.com/hg-011942.html?ref=lexity&_vs=google&_vm=productsearch
Jul 03, 2014 | Game ON SandPro 50 Sand Filter and Pump...
Fuel tank
Take it to a traditional plumber, who can work with solder to have it soldered, or anyone who can do soldering.
Oct 08, 2017 | Kelty Yard King 21" Push Lawn Mower w/...
Poor weld quality- porosity. non directional arc, dcen.
Tig need to very clean prior to weld.Stainless steel wire brush.or dics sand new disc. Argon Gas.
Tungsten needs to be ground the write way. seen Miller.com they have free info for you.How to Tig.
Feb 19, 2011 | Welding Tools
How do you ignite a Lincoln Electric Welder???
You don't need an striker with a MIG welder just hook the ground cable to the base metal point the nozzle where you want to weld and pull the trigger and it will weld. Household current will run a MIG welder Take a look at the plug on the welder if it will pug into a 110v outlet you are all set, but most likely you will need a 220v outlet and maybe as much as an electric dryer type outlet.
It takes a lot of practice to be a decent welder you also need to know what voltage and wire speed settings to use for a given thickness and type of material.
You don't mention shielding gas, if you are using a flux core wire you don't need it, but if you are using regular wire you do.
If I may make a suggestion, If you really want to learn how to weld, find a community college near you and take an introductory welding class. You will get a wealth of information and practice on different welding processes. The instructor will work with you and get you welding much better and faster than you will on your own. Most importantly you will get a lot of safety information.
This is a good introductory book:
http://www.amazon.com/Welders-Handbook-RevisedHP1513-Cutting-Oxyacetylene/dp/1557885133/ref=ntt_at_ep_dpt_1
Mar 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Miller welder bobcat 225 won't weld, terminal broke on voltage regulater, replace same but still won't weld.
Check the terminal connections. How old is it, brushes on that thing are pretty fragile
Dec 28, 2009 | Welding Tools
Bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Dec 18, 2008 | Welding Tools
Welding bearing girdle for Hobart A200?
yes the cast can be welded(brazed). if you are able to weld this yourself, just remember before you can weld it, you have to heat it till it is cherry red then you can weld the piece. if your not qualified to weld it you can usually find a portable welding company to do this for you. hope this helps you please rate the solution...thanks
Sep 18, 2008 | Hobart A200 Stand Mixer
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
