Question about Dell (E210882) Motherboard
Dell Deminsion E310 will not boot
My Dell Deminsion E310 will not boot. The leds on the front have digits 1 2 3 4. 3 and 4 lite indicating a memory or motherboard problem.
I have replaced both at the request of Dell support. Still having the same issue. I received the MB and memory directly from Dell.
I suspect power.
  • sebastian123 Dec 21, 2007
    The desktop will not start the memory or hardware test. Or is failing at the first test. I never see anything on the monitor.
  • itsredsturn Dec 16, 2008
    does anyone know how to fix this? Or what could be wrong? I bearly use this computer and only about 3 years old with lots of memory
  • 383 Answers
NTOSKRNL.EXE is missing or corrupt. To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 20, 2007
Dimension E310 6 beep
if the beep pattern and led light pattern it's a memory problem, try reseating the RAM. Problem and solution is described multiple times here
Dimension E310 won boot up 6 beeps
21.June.2015
Apr 18, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Issues with 2gb 32ddr dell memory compatible in dell gx280
Unfortunately, the CPU on these computers may be capable of handling the 2GB memory, the motherboard isn't on either system.
The specs for the Dell GX280 are available here: http://support.dell.com/support/edocs/systems/opgx280/en/ug/specs02.htm . This system takes 400 or 533 MHz DDR2 non-ECC memory and the form-factor determines the maximum memory. In the mini-tower format, you have 4 DIMM slots and can have 4 GB of memory. In the small form factor, it takes 2 GB max.
The Dell E310 specs are available here: http://support.dell.com/support/edocs/systems/dim3100/en/sm/specs0.htm . This system can only support 2 GB (2 x 1 GB) memory.
I wish that I had better news for you.
(who had a similar Pentium 4 computer with the 1 GB limit. Since that system was running a 32-bit system and only actively addressed 3 GB, I didn't try to put 2 GB sticks in any of the 4 memory slots.)
Aug 30, 2012 | Dell Computers & Internet
I do not have my dell system recovery cd for my dell desktop deminsion E310 I need to to a recovery back to the factory state can this be done without the CD?
YES WHEN YOU BOOT UP LOOK AT THE OPTIONS,HAVE TO DO IT
FAST IT WOULD BE UNDER RECOVERY OR YOU CAN SCAN FOR PROBLEMS
LOOK AT THE OPTIONS IT SHOULD SAY RESTORE TO FACTORY CONDITION BUT YOU WILL HAVE TO HAVE A USB HARD DRIVE WHICH IS EASIER TO SAVE ALL YOUR PERSONAL STUFF MAKE SURE YOU TAKE YOUR TIME AND DON'T MISS ANYTHING THAT'S INPOTANT TO YOU FIRST.THAT'S WHAT I DID.GOOD LUCK
Feb 13, 2011 | Dell Dimension E310 PC Desktop
Dell e310 get black screen with cursor blinking after dell splash screen. F12 not responsive. front panel shows power green and number 123 are on. Thanks
According to the any brand code correct but some time code are same and problem is differ so change slot and try reboot and go to the BIOS and disable memory module single slot check it only slot me be possible memory slot is not working dot depend on dell support form only try differ
Dec 30, 2010 | Dell Dimension E310 PC Desktop
Dell desktop deminsion 1100 wont start up normoly missing primary disk drive (A)when push F-8 NOTHING HAPPENS NORE CTRL F11 WORKS.F-2 TO CONTINUE TAKES ME TO WINDOWS BUT THEN FREEZES EVERYTIME I TRY TO...
A frozen computer is an indication of least memory capacity. aslo, a frozen program during computer restoration is an indication that no hard drive exists in the motherboard on which programs would be loaded onto the desktop.
The computer is missing two parts
1. a hard drive storage
2. a disk driver on which programs would be downloaded on the computer
fixing the problem
1. first perform a hardware parts observation
2. acquire missing parts
Dec 21, 2010 | Dell Dimension 1100 PC Desktop
Dell Dimension E310 won't boot up
this could be your motherboard, but could also be your video or audio card too. try making sure those are seated properly or try replacing one or both, if you so desire.
Jan 18, 2010 | Dell Dimension E310 PC Desktop
Have a Dell Latitude D600 will not boot. All LED
LEDs indicate a memory error
Reseat RAM and try modules one at a time. If ony 1 module, replace it
Dec 16, 2009 | Dell Latitude D600 Notebook
D610 boot failure
Remove all drives, Memory and wireless cards, see if the indication changes. If no change, replace the motherboard. If they change, add memory back one module at a time, see if the system will post. If one does, then the other is bad.
Apr 03, 2009 | Dell Latitude D610 Notebook
Dell dimension E310 crash
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
May 02, 2008 | Computers & Internet
Dell (E210882) Motherboard Logo
119 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
