Kenwood KAC-9103D Car Audio Amplifier
Repairing a kenwood amp
posted by sarcastiq on Dec 20, 2007
I'm trying to repair this kenwood amp because im not getting anything when its connected. I need advice as far as do it your self maintenance. any suggestions?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 22, 2008
Not Rated (0)
crl016
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Check for dry joints. mien had same problem
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on repairing a kenwood amp:
I don't want to Accept this solution
Solution #2
posted on Dec 20, 2007
Not Rated (0)
pbabin
Rank:Guru Guru
Rating: 89%, 301 votes
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Thank You!
Can you Help with these Car Amplifiers problems?
Car Amplifiers
I' ve got a 4 channel 1600 watt v-trek amp (can be...
Car Amplifiers
I have a boss rev 755 that is burnt two little things out....
Car Amplifiers
This amp was barely used, I took my time and did...
Car Amplifiers
need to find out how to connect a new cd deck to the...
Car Amplifiers
I need a schematic for an MA 744C amp from Majestic. It...
Loading problems.
Repair Service
Find Car Amplifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
