Question about Nextar X3B GPS Navigation System
Nextar x3-02 will not go past loading screen
  • 9 more comments
  • Anonymous Dec 30, 2007
    I have the same problem. I am going to try to turn the unit off using the small switch on the back.
  • Anonymous Jan 05, 2008
    my nextar
  • Anonymous Apr 07, 2008
    i will never buy anything from nexter it is sitttt
  • Anonymous May 02, 2008
    stays on loading screen will not reset
  • bigal2369 May 02, 2008
    stuck on loading screen will not reset
  • Anonymous May 06, 2008
    Will not get past the loading process.
  • Anonymous Jun 08, 2008
    My Nextar GPS system will not go pass the loading process. What do I do?
  • melbaack Jun 19, 2008
    will not accept my address in "set home" so I can't get my further.HELP
  • Anonymous Aug 31, 2008
    turned on and off and pressed reset buttom
  • Anonymous Sep 08, 2008
    wont go past loading screen and will stall
  • b_handwerk Sep 08, 2008
    system won't go past loading screen and will stall
Nextar is sucks mind it says system scanning please wait and it will never pass that
Posted on May 29, 2008
I just bought one P3. The SD card does not load the maps!!! I am going to return right away...
Posted on Apr 03, 2008
My nextar x3b gps screen is frozen on loading
NOT SURE
PLEASE TRY WITH THE RESET BUTTON
Aug 27, 2012 | Nextar X3B Car GPS Receiver
Frozen Nextar mp3 player screen
ur mp3 lcd is damaged and the other problem in ur software when u can format it then it will work ok
Mar 11, 2010 | Nextar MA933A MP3 Player
My x3t is frozen at logon screen help
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Please remember to rate my answer. Thanks.
Jul 02, 2009 | Nextar X3-02 GPS Receiver
NEXTAR 14-bct KEEPS FREEZING UP.
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Feb 23, 2009 | Nextar I4-BC GPS Receiver
Cant get past the system scanning ?
I have the same proble, just push one or two time around the right bottom corner of the screen and it should proceed to the next step.
It works for me.
Aug 14, 2008 | Nextar P7 GPS Receiver
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 | Cameras
MY NEXTAR MA9336A1S IS STUCK ON THE NEXTAR SCREEN
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Apr 06, 2008 | Nextar MA933A MP3 Player
Nextar HGPS35
I found this on Nextar support site. These units **** lots of problems being reported by many users.
Q: It (GPS) freezes on the "loading" screen. Why?
A: Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Jan 13, 2008 | Nextar X3B GPS Navigation System
Mp3 player nextar ma715
http://www.nextar.com/frontend/proddetail.asp?pn=MA715&co=10000309
click on the MA715.pdf under the Downloads on the right of the screen.
Later
Nov 30, 2007 | Nextar MA7151B MP3 Player
Nextar X3B
let the batter die. then hold the reset button and plug it in at the same time. itll take a second but i loaded up for me after a couple seconds.
Nov 24, 2007 | Nextar X3B GPS Navigation System
Nextar X3B GPS Navigation System Logo
217 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
