Question about Craftsman Garden
My lawn mower vibrates alot after I crank it - Craftsman Garden
  • 437 Answers
Have you it something, the crankshaft on the bottom of the engine may be bent. Or the blade and blade adapter may need replacing because they are out of balance.
Posted on Sep 30, 2009
What caused a vibration in the handle of my push mower?
a bent crank shaft or a damaged blade. have the blade balanced. should be good. unless you have hit something and damaged the crankshaft.
Apr 21, 2016 | Garden
Kohler k321 cast iron line vibration how to fix
see if motor mounts come loose the engine dont have heavy vibration take to dealer look for crank bearing is bad or rod is loose let dealer check for this hopefully just loose motor if short block 400.00 to 600.00 dollares bad situation think about buying new motor think this over or maybe if old mower replace it
Sep 01, 2014 | Cub Cadet Garden
Craftsman excessive vibration problems 625 series
probably a bent crank shaft or blade is out of balance
Jun 07, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Excessive vibration > lawn mowers
bent crank shaft or blade out of balance
Jun 07, 2014 | Craftsman Garden
My poulan pro 550 series is vibrating a lot when I started. And the front wheel drive is not working anymore.
you need to unplug the spark plug then turn the mower on its side sounds like you hit a rock and bent something and if you bent the crank the belt might have fallen off
Jul 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
The mower vibrates a lot
Either the blade is badly out of balance/bent or it has hit something hard enough to bend the crankshaft which I have seen happen quite a few times. It could also have sheared the flywheel key causing the engine to be out of time but usually when that happens they won't even start and run.
May 18, 2012 | Garden
I've recently inherited a power devil 3hp lawn mower i am a mechanic by trade so i uderstand engines but after using the mower a few weeks ago there was alot of vibration when running now i've come...
Vibration is normally from a poorly balanced blade, a loose blade, or the crankshaft is bent due to striking an emovable object on the lawn, check all these points, if it has been like this for a while it may well have sheared the flywheel key now, if it snatches on the starter rope it is the key or a loose blade.
Aug 21, 2011 | Garden
Started to vibrate and stopped working when I passed over roots.
you had the mower up on it's front oil leaked in the head take the plug out and pull it a few times to clear the oil out and clean the plug it should take of the problem
Jun 26, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
The mower vibrates hard I replaced the fan and
you could have a bend blade or bent armeture shaft if you hit something that hard
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Garden Logo
338 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
