Question about Electrolux Dryers
Need to know how to change heating coil in white westinghouse dryer model number wer211eso
  • 304 Answers
The link below discusses disassembly of models similar to yours. The main difference is that the manual covers models with front controls whereas yours has top controls.
Unplug dryer. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior.
Continue with "Removing the drum" on page 69. Having removed the drum exposes the heater behind it and safety thermostats above the heater shroud. The heater is generally purchased and replaced as a coil only not as a complete assembly as described in step 4 of page 72. Look for a break in the coil by touching all sections until found. If the break is not found check thermostats, motor switch at back of motor and heat contacts in timer for open circuits. Repair as necessary.
Reverse above process to reassemble.
Dryer Service Manual
Posted on Oct 01, 2009
Location of fuse model WER211ESO dryer
The fuse is probably related to the mains plug fuse and unlikely to be this as the machine switches on. Possibly the heater or heater thermostat. You may need a engineer to confirm which one.
Jan 17, 2014 | Electrolux Dryers
I need to know which color to connect to which connectors on the timer of a wer211eso dryer. george
here is a wiring diagram:
http://www.applianceaid.com/images/swfedwd.jpg
Oct 27, 2010 | Dryers
Dryer was not heating up yesterday ...but working this morning ???? second time this has happened ....
you have bad gas coils.when the coils are starting to fail they work until they heat up and then stop working until they cool down and then they will work again,the dryer will work correctly for the first 15 to 30 minutes,then the coils will heat up and stop working not allowing the gas to come in, the gas coils are on top of the gas valve,remove the two phillips screws,remove the cover and change out the coils,easy repair.let me know how you make out.also next time you need help send the model number so whoever is helping you they can look up your machine.
Jul 02, 2010 | Kenmore 73952 Gas Dryer
Dryer starts aand gets hot for about 10min then the heat shuts off and will not come back on
you have bad gas coils.common problem,the coils will work until they heat up then they fail,the coils are located on top of the gas valve,very easy to change,let me know how you make out,call your parts store and give them the model number and they'll give you the coils
May 08, 2010 | Kenmore 73952 Gas Dryer
Need to know how much heating coil cost on my 70 series kenmore extra capacity dryer.
open dryer door and get model # 3 numbers a period and 6 more #s, they varry in price from $30.00 to $100.00
Dec 09, 2009 | Kenmore Dryers
Dryer heats up ,then loses heat after 10 minutes
Based on your description, you may have a Gas Valve Coil failure. Below is a link, courtesy of www.repairclinic.com, showing the part(s) involved. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8c237i3479&PartID=3479
More assistance below: You will need your model number to access the information.
Model Number Locator Tip
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag.
1. Parts Breakdown/Disassembly Procedures: http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
2. Diagnostic tips: If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 27, 2009 | Maytag Dryers
No heat
Based on your description, it sounds as if your gas valve coils may be malfunctioning. This has consistently been the number 1 failure.
This link shows an image of the coils. You will need to provide the model number off your dryer product ID tag.
Tip:
Model Number Locator Tips
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i3479&PartID=3479
This link shows parts breakdown and disassembly procedures.
1. http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here are some things that could cause your problem.
2. If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Aug 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't heat
i only ask this because you mentioned the loud noise are you almost out of propane, is it a pop sound or ?
Jun 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Whirlpool model LGR7648KQO does not heat.
Hi. By "heating coil" I am assuming you mean the dryer's ignitor?
What is probably wrong is the white thermal overload has opened up. You will find it mounted on the blower duct and usually has two light blue wires going to it with smaller spade terminals than the rest of the thermostats. You check it with an ohmmeter for continuity. This is a very common problem on those dryers and it usually opens up if the dryer vent is obstructed or needs to be cleaned.
The part number for this thermal overload is a
3392519. On your model, you have to take the back off the dryer and look for it to be mounted on the blower duct. You can't miss it. It's white plastic with a brownish colored center (looks like epoxy) where the terminals are.
Hope this helps and good luck. Thanks for using the FixYa service.
Mar 15, 2009 | Whirlpool Dryers
Dryers Logo
449 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
