Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not keeping temp.
My refrigerator is not keeping temp. the freezer is working, but the fridge is not staying cool enough. the appliances came w. the house so they should be no more than 2 yrs. old! We have tried to turn off the bottom half but nothing seems to work.Any advice plz
Erica
  • Johnny
    Johnny May 11, 2010
    any water build up in the fridge section? does the door gasket look ok? can you feel any cold air blowing into the fridge section? is the fridge tightly packed(crowded) with food?
    Problem Solver:
  • 7 Answers
There is normally a fan in the freezer (usually removing the back panel from inside the fridge will show it [sometimes you need to pull the bottom panel of the freezer off] The panels are normally secured with phillips head screws.). If it doesn't turn, it probably needs replacing. Make sure the coils are not iced over. [unplug while removing panels, then plug back in... the temp will have risen in the freezer so the fan should come on right away].
Make sure that the "vents" in the freezer (bottom of the freezer - in the front back or both) are not covered.
Some fridges have a separate control for fridge temp, make sure that was not moved, or try setting to a colder setting.
Posted on Jan 15, 2010
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
GE TBXW25R Refrigerator does not keep cold enough temp in freezer and Freezer has a build up of frost begining
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | GE Refrigerators
Refrigerator not keeping cool enough. Freezer staying cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 26, 2011 | Maytag MTB2656G Top Freezer Refrigerator
Not cooling enough
I had the same problem and I discovered it was the defrost element that was shorted out which keeps the ice from building up located behind the back freezer wall.
Aug 09, 2009 | Refrigerators
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Refrigerators
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
221 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
