Question about Sewing Machines
Kenmore 158.17921 Need to know where to oil? machine sticks at times. Do not have a owners manual.
  • 208 Answers
Remove the two large screws that hold the top lid on and remove the lid. Open the left side cover where the needle bar and presser bar are. Place one drop of oil on everything that moves. Oil moving parts on the bottom. Blow off excess oil with an air compressor.
Posted on Oct 01, 2009
Where do I oil Kenmore Model No 385 16221 can't find it in the manual
Page 94 of the manual:
Kenmore 385 16221 Owner Manual Table Of Contents
FWIW, it is important to keep your machine clean and oiled for it to operate properly. Use ONLY good quality sewing machine oil and apply ONLY 1-2 drops every place indicated, approximately every 40 hours of sewing time.
Dec 23, 2016 | Kenmore Sewing Machines
How do I oil a Kenmore 385 sewing machine
Are these the pictures you have?
KENMORE 385 12612090 Owner Manual Oiling The Machine Oil The Underside
Something you can do is slightly wiggle the handwheel (do not turn it in reverse). The handwheel should always turn toward you.
Look at the pictures and watch where metal rubs on metal that might match the picture and apply one drop of fresh, good quality sewing machine oil.
Aug 04, 2016 | Kenmore Sewing Machines
What about Oiling?
If you look at the Oiling Instructions in the owner's manual, it has a picture of where the oil should be applied. Only one or two drops!! It should probably be oiled frequently--about every 8 hours of sewing time. Pfaff probably sells a sewing machine oil for your machine. Just tell them your machine model and they should know what you need. Do NOT use 3-in-1, WD-40, cooking oil, or the old stinky brown stuff from grandma's sewing basket!
Feb 24, 2016 | Sewing Machines
Stuck reverse button on kenmore 158.17011
I believe your Kenmore is an older mechanical machine. If so, how long has it been since you've given it a good cleaning and oiling? Mechanical machines need frequent TLC, otherwise the old oil turns into a glue-like substance and starts sticking things together, including your selector levers and dials. Give your machine's bobbin area a good cleaning with a soft brush to remove dust and lint.
Then, use ONLY fresh good quality sewing machine oil. Open the case top and free arm cover (if it has one--if it is a flat bed, tilt the machine back so you can access the moving parts under the sewing surface), gently handrotate the handwheel toward you, watch where metal rubs metal and apply 1-2 drops of oil. (Your owner's manual may have instructions for oiling and your machine may also have oil ports--little holes-- where oil should be applied.) Do not skip the feed dog moving parts. Also, there is usually an oil port behind the bobbin mechanism next to the case. Put a single drop of oil on the bobbin race. Do NOT oil plastic, rubber, or belts! Be sure to move the selector levers and dials and, if possible, apply a couple of drops to their moving parts as well. To help loosen things quicker, direct hot air from a handheld hairdryer into the internal mechanics of the machine. Repeat the oil/heat process until things are moving freely.
In the future, be sure to give your machine a thorough cleaning and oiling after about 40 hours of sewing use. A drop of oil on the bobbin race is good every 8 hours. If your machine sets unused, oil every six months to keep it operating.
Nov 19, 2015 | Kenmore Sewing Machines
I'm trying to oil my machine, but don't know how to get the face cover off??
Perhaps the Owner's Manual will help:
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/38515358.html?p=1
Be sure to use good quality sewing machine oil and white grease as explained in the manual.
P.S.--from the manual's instructions, it appears that you do not need to remove the face plate to oil your machine.
Sep 14, 2015 | Kenmore Sewing Machines
I need a manual/where to place oil
go to the website of sewvacdoctor.com & email them about the machine to see if they know where you can get a manual & oiling
Mar 04, 2012 | Kenmore 15208 Mechanical Sewing Machine
Where to oil a Kenmore 158-17600
Remove the top and bottom covers. Turn the wheel and put a drop of oil anyplace that moves and rubs.Also at the ends of each shaft. Open the side cover and oil the needle bar and all the parts inside that move and rub.Put a drop of oil on the hook.Do not put a good piece of fabric in the machine right after you've oiled it. Sew it off on some scraps that you can throw away.
sewman7
Apr 18, 2009 | Kenmore 16622 Mechanical Sewing Machine
Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
Oct 25, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
