Hi I am using a rca hdtv as a moniter but I
Hi I am using a rca hdtv as a moniter but I cannot ajust the resolution above 640 x 480
Is there an ati driver available that I could use
  • 55 Answers
Try this link for details, hope it helps http://www.devicemanuals.com/guide/Television/RCA-manuals.html
Posted on Sep 30, 2009
MagicTune for Samsung Syncmaster SA100 (S22A100N)
i can not adjust my samsung sa100 moniter's resolution.
Jan 04, 2012 | Samsung Computers & Internet
Is the ati radeon mxm II 512mb card a reasonable graphics card? Thanks
I am not very sure which ATI you meant, but I assume myself as ATI Mobility Radeon HD 3650 MXM II Graphics Card 512MB, which is compatible with MXM II graphics slot Laptops. It's a good graphics card and it supports high Resolution. For your reference, I include the following descriptions about the Interfaces and their respective resolutions:
# Two integrated DisplayPort outputs
* Each supports 24- and 30-bit displays at all resolutions up to 2560x16001
* 1, 2, or 4 lanes per output, with data rate up to 2.7 Gbps per lane
# Two integrated 400 MHz 30-bit RAMDACs
* Each supports analog displays connected by VGA at all resolutions up to 2048x15361
# HDMI output support
* Supports display resolutions up to 1920x10801
* Integrated HD audio controller with up to 2 channel 48 kHz stereo or multi-channel (5.1) AC3 supporting Dolby Digital or DTS, enabling a plug-and-play cable-less audio solution
# Integrated AMD Xilleon™ HDTV encoder
* Provides high quality analog TV output (component/S-video/composite)
* Supports SDTV and HDTV resolutions
* Underscan and overscan compensation
# MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding
# Seamless integration of pixel shaders with video in real time
# VGA mode support on all display outputs.
You can also check out the full specifications here (Click Here).
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Dec 30, 2010 | Computers & Internet
Tv resolution
It will produce 1080i or 480p using the component input jacks. No way as sharp as 720p. This is of coarse your cable provider gives it to you, and your using a box.
Dec 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I can not connect my rca dlp HDTV to my hp laptop. I tried using VGA wire, laptop is fine but TV is showing unuseable signal
A lot of TVs only accept limite PC resolutions. Try 1028x768 60hz this normally works.
The Error message doesn't mean the TV or PC is not working, only that the signal is not compatible. try all resolutions until something works.
Jun 23, 2009 | RCA L26HD31 26 in. LCD HDTV
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
Screen resolution always get back to a different value
There is most likely a utility ( ati util ) that runs in the background so set the resolution through there utility and that should solve the issue where as if you set it through windows display properties it will continue to do the above.
Apr 15, 2009 | IBM ThinkPad T43p Notebook
My laptop doasn't regonize my tv when i connect it
I would suggest that you should reduce the screen resolution of your laptop to something like 800 by 600 pixels, then try to reconnect it.
This is because there are some TVs that can not display the resolution provided by some high-end laptop graphics card, and I have actually experienced a case like this before.
So just try and check some lower resolutions on the laptop to connect it to your TV.
Hope it helps you out.
Mar 31, 2009 | Computers & Internet
PC via DVI to D52W20
I'm using a component dongle from an ATI x800. Never have had a problem. My resolution is 1664x936. I noticed that this RCA auto formats the screen size with the DVI-D or component, so you'll have to make the adjustments via your video card. Windows display properties might not let you select that resolution, so hopfully your video card software will allow you to pick a resolution. It would not let me use any kind of 720p resolution only 1080i settings would work.
Nov 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lenovo T60 interfacing with Vizio HDTV using RGB cable
The X1400 supports Full-HD resolution. Full-HD/True-hd (1920x1080)
The best output would be via DVI but you are limited with the VGA port.
I would purchase a Grand Hi-Wire PC to HDTV converter from www.globalcomputer.com. Item # G126-1036 @ $139.99
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
