Question about Epson Stylus Photo R300 InkJet Printer
GETTING HORIZONTAL LINES ABOUT 3/16" APART- SEEMS TO BE IN THE BLACK OR THE CYAN -NO LINES IN FLESH TONES, ETC.I RAN THE HEAD CLEANING AND THE ALIDGNEMENT A FEW TIMES
  • 2 more comments
  • amdet Sep 30, 2009
    I am on a mac 10.5 MacBook Pro
    How do I move the ink cartridge tray into position?
    The lines are voids in the cyan and black [ mainly the black]
    Again I AM on on a MACBOOK PRO 10.5
    HOW DO I ADVANCE THE INK CARTRIDGE CAGE INTO POSITION SO I CAN TAKE THE CARTRIDGES OUT!
    I STILL CAN NOT GET THE INK CARTRIDGES OUT - CAN''T GET THE UNIT TO MOVE TO THE 'TAKE OUT" POSITION. I WENT TO THE UTILITIES AND THE INK CHANGE - NO LUCK!!!!
    I WOULD LOVE TO FOLLOW YOUR CLEANING INFO - BUT, I STILL CAN NOT GET THE INK CARTRIDGE TO STOP AT THE RIGHT LOCATION. I DO NOT BELIEVE YOU ARE GETTING MY MEMOS!!!!
    President:
  • 1,884 Answers
If head cleaning and alignment have not worked try changing the cartridges to ensure that the printer minus the cartridges is alright. If there is any fault with the cartridges, as you say black and cyan are the cause of worry, try changing them with new ones. Yes I agree it is an added expenditure but better than changing the printer and then finding out that the cartridges were faulty. Best of luck.
Posted on Oct 01, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The horizontal lines appear while printing if the ink dries up and while printing these spots are missed and it appears as dark horizontal lines. If the printer is not used for a long time, the inks in the cartridges dry up and these lines appear. Remove the cartridges, clean the cartridge slots with a soft cloth and reseat them after a minute. Please do this while printer is turned off.
You'll also need to perform printhead cleaning. To check these out in Windows XP, click Start and then Printers and Faxes. Right-click on the printer and click on printing preferences. This displays the Printing Preferences dialog box, which houses various layout and print-quality preferences, as well as the printer’s maintenance options.
Click the Maintenance tab to view what your printer can do from a software perspective. There will be 2 cleaning modes—cleaning and Deep Cleaning. Cleaning isn’t quite as time-consuming as the Deep Cleaning mode, but Deep Cleaning mode does a more thorough job and can resolve some issues that the normal Cleaning mode can’t. Just click the proper cleaning mode to start it and let the cleaning process run its course. You may have to do this a number of times to get the print head clean.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 30, 2009
  • Rylee Smith
    Rylee Smith Sep 30, 2009
    Hi
    Open the Applications folder on your hard drive, then open
    the Utilities folder and double-click the Print Center
    or Printer Setup Utility icon. Select any one of the appropriate printers from
    the list, then click the Configure or Utility button.
    Follow the steps below to clean the print head using the
    Head Cleaning utility--
    • Make
      sure that Letter-size paper is loaded in the sheet feeder.
    • Make
      sure that the EPSON PRINTER is on and the “!” Error light is off.
    • Access
      the Epson Printer Utility dialog box.
    • Click
      the Head Cleaning button in the Utility dialog box.
    • Follow
      the on-screen instructions.
    • Head
      cleaning... appears on the LCD panel while the EPSON PRINTER performs the
      cleaning cycle. Also see this link for details---
    Print head cleaning
    Caution: Never turn
    off the EPSON PRINTER while Head cleaning... appears on the LCD panel. Doing so
    may damage it.
    When Head cleaning...
    disappears from the LCD panel, click the Confirmation button in the Head
    Cleaning dialog box to print a nozzle check pattern. Use the check pattern to
    confirm that the print head is clean.
    If the print is good: Print head does not need to be cleaned
    again.
    If the print is Not Good: Print head needs to be cleaned.
    If the nozzle check page does not print satisfactorily, you
    may need to repeat the head cleaning and print the nozzle check pattern again.
    You can manually clean the printhead by--
    Take out the black and color cartridges. Put them on a suitable
    dish or tray upside down. Put a few drops of alcohol in the ink holes to keep
    them wet. Repeat as needed - don’t let them dry out. Keep plenty of paper
    towels handy. Put the black cartridge
    filled with alcohol into the printer. Look into the color cartridge holder. You
    will see a shiny metal tab. When this is depressed it tells the printer that a
    cartridge is in the printer. Look at the indicator light next to the power
    switch. The green light will be on. Push the tab, it will go off. This tab must
    be depressed for the cleaning function to work.
    The indicator light will be off when you get it right. Put
    several drops of alcohol into the colored ink wells before blocking the tab and
    closing.the lid. You could use an old, cleaned-out, colored ink cartridge for
    this if you wanted. With the alcohol cartridge in place and the colored side
    rigged, clean to your hearts content. You will run alcohol through the black
    side and not waste any colored ink in the procedure. The above technique can be
    reversed or varied to clean the colored heads.
    Thanks
    Rylee
My brother CIP-J140W is only printing in cyan. I had accidentally put the cyan cartridge in the black cartridge spcae. Despite changing them around, cleanre the head etc, it is still only printing in cyan....
Oops, You really have to print, selected black, till all Cyan ink is gone. This could take a while. Cleaning the head, won't solve anything.
If you really want to clean the ink out of the head and everything, you need special cleaning fluid. Refill shops do have this fluid. You should bring some cleaning fluid in the tube under the black cartridge, in the tube where the ink is going in. If you have a syringe you could try to gently press some fluid through the tube. Not to strong. could damage the head.
After placing back the black cartridge, select clean the head and let the printer do some black and withe print jobs, till the cyan is gone.
Nov 27, 2013 | Brother MultiFunction Center MFC-440CN...
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
Aug 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Epson Stylus T10: Horizontal bands when printing cyan
With I could post a solutions but I have the same problem! Cyan has horizontal gaps, rest of the colors seem to be ok. I've realigned and cleaned the heads many times.
Mar 17, 2009 | Office Equipment & Supplies
Black lines on playback no playback
hi, if you have stuck the head cleaner in and this has not removed the black lines then the head might either need a thorough clean or may be damaged.
Jul 03, 2008 | Panasonic NV-GS17 Mini DV Digital...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Epson 1290 printer
Fix posted yesterday BUT after a few perfect print outs the problem seems to be recurring.... will report back later. Trant
Mar 28, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
