Question about Panasonic PT-47WX51 47" Rear Projection Television
Panasonic pt-50dl54j i get an error code on the power led 3 blinks
  • bobbo29 Nov 09, 2008
    I have the exact same problem with my set. 7 flashes. I can "fix" it by replacing the bulb and get another 3 or 4 hours of viewing before it does it again...
  • Anonymous Mar 12, 2009
    i have panasonic projector tv model nr PT 50DL54J.problem on my tv is colors
  • 80 Answers
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Posted on May 29, 2008
  • Kaya Siva
    Kaya Siva Mar 26, 2017
    Where's the second fan?
I had the same problem power button lights up red and then blinks i email panasonic lucky me they
told i have to replace both fans and maybe the lamp because the fans cool down the lamp on tv so i did it coast $120 it turn on i had no problems no more
Posted on Jan 03, 2009
Hope im in the right spot for this. anyway, my panasonic widescreen dlp tv is having problems. when i turn it on. it will work for about 5 min, then just shut off for no reason. and it will only turn on once it has been unplugged and plugged back in. the problem got worse though, and now it doesnt turn on at all. when you push the power button, it just makes some clicking noises and then nothing. the led on the front flashes 7 times. which from what ive been told is an error code. what does this code mean?? and does anyone have a guess at what could be the problem??
the model number is PT-50DL54J
thanks
Posted on Jun 01, 2008
I have a PANASONIC pt-50dl54J. It will come one for a couple of seconds then shutdown. the power light blinks 4 times.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, or the LED light stationery; the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location./
Jun 17, 2018 | Panasonic Televison & Video
I have a Panasonic HDTV Projection Monitor. PT-50DL54J. When I turn it on, it flashes green on the power button, I can hear the fan, then it stops and flashes a red light 9 times forever. Any tips? Thanks
These blinks to standby light are fault indications. You can get an idea about the faulty circuit section inside it, by these blinks, called blinking codes. If you wish to know more about the blinking codes, http://electronicshelponline.blogspot.com/ check this link. It has details about these blinking codes, to many brand TVs including many models of Panasonic. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 24, 2013 | Televison & Video
Panasonic power led blinks but no picture
The model indicated is a rear projection crt (picture tube type) set.
Count the number of blinks and if you have to: uplug the set and try to turn it on again---most will blink a error code and the most popular are a series of 3 blinks, a pause and 3 more blinks etc.
Let me know the number of blinks and I will attempt to point you to what is wrong.
SD TECH
May 02, 2010 | Panasonic PT-47WX49 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic rear projection 53" TV model PT-51hx43G. Just got this bad boy back from my ex wife and when i turn it on the power led flashes 3/5 times and goes dim. I have checked the power and...
count the led blink as thats an error code. If it blinks three times its indicating the convergence Circuit has failed. Let me know the actual blink number and I will assist you.
Jun 22, 2009 | Panasonic PT-51HX43 51" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
47wx42f panasonic tv
Does the led blink when you press power? If so please let me know the number of blinks as that is an error code.
May 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX51 47" Rear Projection Television Logo
1,091 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
