Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
MTS 2000 I have a MTS 2000 that i use for work. It seems like it was disconnected some how by somebody at work. Is there a way to reprograming it with out having to turn it in and loosing my radio. and how was it deprogrammed?
    Problem Solver:
  • 17 Answers
The radio can only be programmed or adjusted by the use of a computer and the proper software. What exactly is it doing or not doing? Do you keep it on the charger all the time?
Posted on Jan 09, 2008
If it is used on a Trunked or Conventional radio system, the administrator of the radio system can disable the radio over the air (Radio goes dead) or if a trunked radio he can also stop it accessing the trunked system (sometimes you may receive but you cannot access the system with a PTT). It can only really be re-enabled on that radio system by Administrator as they usually leave the disable function ON for suspect radios. On certain systems they can keep track of the radio ie: when it's switched on, what channel and sometimes even covertly switch it to Transmit & listen.
They normally will only do a disable with a lost or stolen radio.
Posted on Jan 11, 2008
Reprogram the computer so the key works I tried to jump starter with screwdriver it would run for A second then stop when turn key it does nothing
no your antitheif is workin property if you jump starter and the engine cut of is because the system is working thry jump start whit the key on the ignition on the runn position is goint to be running and dont stop
Oct 01, 2014 | 2000 Chevrolet Impala
In my psp 2000 when i put the battery in green light flashes automatically but the screen does not work and when i turn it on nothing happens that green flash remains the same please help me somebody its...
You have to reprogram your console. First, create a recovery memory card using Pandora, then, you need an Pandora cracked battery to can rewrite the SW.
Jun 01, 2011 | Video Game Consoles & Games
Ford 2000 excursion keyless entry not working
look online or go to the dealer and find a reprogramming procedure.
Mar 12, 2010 | 2000 Ford Excursion
1.8 focus zetec 99 plate wont start ,have heard that ecu may need reprogrammed,inertia switch ok,can this be done by disconnecting battery for a few mins then reconnect it?
its worth a try but dont hold your breth as it may well not work,,,if you disconnect the battery you will need the radio coad to get the radio working again,,,and you may need to reprogram the car alarm????
Feb 23, 2010 | 2000 Ford Focus
I have an old NEC TV, NEC MTS dbx Stereo reciever/monitor, from the 1980's. It has not be used in over five years and now I want to use it. Everything seems to work fine except I only get the first 14...
If there is no cable switch anywhere (make sure you check the back where the cable screws on) you will have to have a converter box to change channels with. When using a converter you put the TV on channel 3 or 4 and switch channels on the converter. Thanks
Oct 22, 2009 | Televison & Video
Electric Windows don't work well (Mercedes C240 1999)
hello Tony. Hold the Switch till the window is down. Hold the switch down for 4 seconds afterwards and it will reset. Do this will all the windows and the sunroof.
Oct 02, 2009 | 2000 Mercedes-Benz C-Class
INCOMMING CALLS
Check with your carrier to make sure your service has not been disconnected/suspended. This could be the problem or your device may need to be reprogrammed which also your carrier can assist you with. Thanks.
Mar 26, 2009 | Samsung SCH-u340 Cellular Phone
Installed new steering column, computer reprogram.
I dont dont think so it should have been compatible first or you would have lights on/ thats just another 110.00 for them to program it/ Thanks for using fix ya Please rate my response thank you very much
Jan 30, 2009 | 1994 Buick LeSabre
Mts 2000 vhf constant tone
The scan is on and you do not have a scan list programed.
This is the most common problem connected to your post. Hope that helps, Bill.
Jan 02, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
194 people viewed this question
Top Motorola Radio Communications Experts
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
