5 rapid red blinks on the LED
I have a Pioneer Plasma PDP-503PE. It stopped working and whenever I try and turn it on it just starts blinking 5 rapid red blinks on the LED.
Any thoughts on what it might be?
  • samjallen Oct 01, 2009
    No device was connected to teh TV - I found the manuals and they said that 5 blinking red LED's meant the power supply had failed.
    Any ideas where to get a well priced one at all? Or could ti just be some resisters need replacing? I hear they pop after abotu 1000hours on a lot of TVs
  • 360 Answers
Solution for error 1, 5 beeps,
For video data transmission from the Media Receiver to the PDP-434HD
and PDP-504HD-series Plasma Displays, digital signals are used.
Therefore, this unit adopts the HDCP (High-bandwidth Digital Content
Protection) system for copyright
protection. This unit is also provided with a detection switch (TRAP
switch) that will prohibit the unit from being turned on again "if the
upper plate of the unit is accidentally opened," in order to prevent
the panel technology from being leaked out.
The TRAP switch is disabled while the unit is turned off. When
performing internal diagnosis of the PDP, fix the switch to the OFF
position using adhesive tape before turning on the
unit. After servicing, be sure to remove the adhesive tape.
Well you've probably guessed what my next question is......How do i
unlock this receiver?. I'm told that it's simply a matter of keying in
3 buttons of the remote in a defined sequence. I have the service
manual but it doesn't say much about unlocking.
"The next generation of Blu Ray players will be equipped with
powerful explosives that will kill everybody in sight if the unit detects
possible tampering or if someone puts a DVD+R in it." )
( They use a photocell to kill the DVI board if light hits it
(as in the backboard removed). The TV continues to work, but not in
HD.
bypass the Pioneer's switch, or put black tape over the photocell.
Posted on Sep 30, 2009
  • 7 more comments
  • Richard Klein
    Richard Klein Sep 30, 2009
    In short your TV needs a service adjustment.
  • Richard Klein
    Richard Klein Oct 01, 2009
    IF resistor shorted-
    POWER ASSY(AWV COUNTER
    DIGITAL VIDEO ***'Y
    The manual can be downloaded from PDFOO.com
    It shows you how to do about very thing needed to fix it if your a Tech
    This error has caused a lot of peoples TV to fail.
  • Richard Klein
    Did you have any device connect to the TV?
  • Richard Klein
    The five beeping lights is audio failure IC5000 Shutdown 3 seconds after waring. Shutdown by warning of speaker failure. Need to check and secure, proper connection to speakers.
    I guess you just can win because, either way your will still have to have a service adjustment, and buy the x y boards too. But, it may even be worst, because when they replace everything, their going to install a nice little inductor between everything in addition. The additional upgrade that they'll preformed is to allow the TV to have a good stability and strength. Hope this helps.
  • Richard Klein
    Richard Klein Oct 02, 2009
    It is possible since I'm overwhelmed, and new at FixYa. I believe I had the right code but, you may try to bid one on ebay, A lot of times, you can set your bid and get it cheap. The resistor can be pick up at any electronic supply company and are not that much. I still encourage you to do the service adjustment no matter what the fault. Power supply goes out, it's real hard on the other components and may have damage something else.
  • Richard Klein
    Richard Klein Oct 05, 2009
    G3 P2 board power supply problem, check for fuses blown in and around p2 board and supply, along with any discrete component damage. After repairs you might have to follow trap and release procedures. Thought, I'd tell you that so, you wouldn't get it fixed and not work. Hope this helps!
  • Richard Klein
    I wouldn't take chance on getting a cheap supply, if needed. New one should give less chance of it being shorted, or warn down helping the TV's components.
  • Richard Klein
    I'm sure this is a G3 unit but, is it possible that this model is a PDP-503PU? If it is loaded with extras then it just isn't on my list.
  • Richard Klein
    As far as your comment that some of these parts lasting an 1000hours. Under normal use, that's probably right most of the times.
Hi, I have a Pioneer plasma 'pdp-50mxe20' and when I turn it on it after a few seconds it goes off and the red led start blinking 8 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Dec 28, 2014 | Pioneer Televison & Video
Pioneer PDP-436PU TV blinks red 10 times
Most likely a bad power supply board= you are going to have to find a Pioneer dealer to get it fixed or even get the part--many shops including the one I work for will not touch this brand of set.
Apr 25, 2012 | Pioneer PureVision PDP-4340HD 43 in....
I have a Pioneer Plasma PDP-4360HD (display PDP-436PU) which I thought had a broken Y-sustain board based on the blinking LED warning. I replaced it myself but it it still doing the same thing: no picture...
Usually when you change the Y-sustain you must change the buffer board(s) This is the long thin board(s) on the far left side going up and down in the set.
Oct 18, 2011 | Televison & Video
No picture. Monitor blinks 4 reds. Tv would come on for a few seconds then turn off. Now nothing but blinking lights. what do I do. Thanks
You have may be broke the system cable, the dvi-d cable is broke...
In my pdp-5030hd have the same problem, probe changing the only the dvi cable and works perfect...
The monitor blinks 3 red and the 4 blinks still in red...
Now i will try to put in the dvi-d input another source like a pc...
You need always the Pdp03u box for control...
Sep 12, 2010 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
My pioneer plasma PDP 5060HD Media Center control box has red blinking light, blinking once every second. No power to plasma display and unable to power on media center box. Recycled power to both plasma...
lenwas,
I have the exact same problem with the same model tv. It just stopped working, tv has no lights or evidence of power and the red standby light on the media center flashes without any other function potential.
I checked the internal tv fuse and it was measuring continuity.
If you figure anything out I'd be interested to hear it.
Tom
Jan 05, 2010 | Pioneer PDP-5060HD 50 in. Plasma...
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Media Receiver Shut-down, Blue LED Flashing for Pioneer PDP-R06G
May 10, 2009 | Pioneer PureVision PDP-4340HD 43 in....
No picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
Dec 10, 2008 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
546 people viewed this question
Top Televison & Video Experts
Electro Med Services...
