Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Just noticed it has stopped running - have checked fuse and it is ok. other plugs in the area are powered
Problem solved - outlet was not working
Posted on Oct 01, 2009
Dishwasher has no power to control panel and fused spur arcing
You state that the fused area was arcing. Any time you have arcing, in time that area will carbon up and stop working. Sound like a loose fuse holder or bad connection in that area. Shut off power, remove fuse and clean area completely. make sure fuse fits tight in holder. Check all connections where you noticed the arcing for black areas that are burned.
Apr 06, 2015 | Dishwashers
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
Cigarette liter stopped working then the next day the blower motor stopped working, Now the buzzer for head lites being left on stopped working and interval wipers stopped as well. This has been within a...
no power, means, what, cig lighter plug dead,?
try something else there, like a cell charger, still dead.?
if it is truely dead, the fuse is blown.
does head lights work, and engine run?
ok fuses that bad are bad, blown. (blown elements)
ok fuse that look GOOD, can in fact be bad, (tiny cracks.)
we never fail to test good looking fuses or go nuts for sure.
you can test fuse 3 ways.
1: DMM ohms, 0 ohms reading
2: voltmeter shows, 12v, on both sides of fuse, key on.
3: a fuse tester dealy bob at any autostore. (ill pass)
there are other ways, but are way too complex to type.
(ok a battery powered test light , yes, all auto stores sell them.
glow with a good fuse)
bingo?
Sep 03, 2013 | 1991 Honda Accord
Hitarchi Hdr081 Stopped working
The power supply is probably the area of trouble, the most common problem is the capacitor, { usually opens } sometimes it will bulge at top leaking.
May 15, 2012 | Televison & Video
I have a 800 hdx grinder and it just stop running no power to the switch
The most likely cause is the plug fuse. Open the plug and check the fuse for continuity. If there's no continuity replace the fuse. If the fuse is ok check that the wiring hasn't come loose. I hope that solves your problem.
Jan 11, 2011 | Grinders
My jamo s260 will not power up
hello make sure you put the same rated fuse back in beware if blows again then you've got a dead short somewhere
regards
shaun
Feb 28, 2010 | Audio Players & Recorders
Turnsignals and blower on heat stopped working at
check the fuse links under the hood near the battery / starter area and also check the main plug into the firewall
Jan 20, 2010 | 2000 Dodge Caravan
Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
