Question about Maytag Neptune FAV6800AW Top Load Washer
My stacking "spacemaster II (Agitator will move clockwise only.)
My stacking "spacemaster II" will not agitate. The agitator will spin (manually) anti clockwise only.Is this likely to be transmission or a broken belt
Dumbo
  • clutz-boy Dec 24, 2007
    thanks dude it turned out to be a broken belt and very easy to fix
    Happy Ho Ho Ho
    Champion:
  • 249 Answers
That sounds about right
Posted on Dec 20, 2007
  • eamonn close Dec 24, 2007
    glad you fixed it,Ho Ho Ho ,from Ire!!
My whirlpool duet stacking washer wont spin or drain. i tried to do it manually as described in my owners manual with no luck
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 12, 2014 | Whirlpool duet Washing Machines
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Sep 28, 2014 | Maytag Neptune Washing Machines
My Frigidaire front load stacked washer/dryer makes a horrible noise and won't spin. It works perfectly except for the spin cycle
you need to remove the agitator take the cap off and remove the bolt from inside the agitator and then remove it look at the metal trunion in the bottom of the tub and see if there is a broken bolt holding the trunion to the shaft.there is a chance the transmission need to be replace if there is no broken bolt
Nov 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Won't spin or agitate
replace coupler between motor and transmission
Sep 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator wil not move makes a growling sound but all spin cycles still work
Either the transmission is bad, or more likely the agitator dogs are broken. If you pull the top pieces from the agitator you can see the agitator dogs and tell if they are intact or broken. If they are good, the transmission might be bad. The only other thing will depend on if the machine goes through the wash cycle to the rinse and spin without ever agitating, or if you have to manually move it. If you have to manually move it, your timer is probably bad.
Sep 06, 2009 | Washing Machines
Whirlpool ultimate care II super capacity plus ser.# LSQ8243HQO The top half of adjitator is not turning at all. Handiman1125@aol.com
If the bottom half of the agitator is turning and the spin cycle works, then the motor coupling is good.
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way). If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
The part number is 80040.
If it there is no agitation or spin, replace the motor coupling.
The part number is 285753A
Mar 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Locked up agitator,
If your agitator is a 2 piece, it has a rachet action and turns free counter clockwise and locks to the bottom piece when turning counter clockwise.
The transmission disengages the agitator when it is in the spin mode. If you put the washer in the spin cycle the agitator should free up.
If the washer is spining ok and the agitator is not turning free you have a transmission problem.
Jan 27, 2009 | Admiral AW22 Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
106 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
