Question about Kenwood KDC-MP235 CD Player
I can't use my ipod.. pressed SCR and only tuner and standby is displayed
I can't use my ipod.. pressed SCR and only tunnr and standby is displayed.
I've read the manual and still don't get it.
I plug in my Ipod in the aux input using the correct cable. Then press he SRC button. Only the "tuner and standby" is displayed. How do I get to the part where I can select AUX/AUX EXT so that I can listen to the Ipod?
Thank you in advance,
Rod
  • 9 more comments
  • rodjava Dec 20, 2007
    Thank you.
    This worked!
    I'm happy now......
  • igli123 Feb 11, 2008
    i dont know how to get the mp3 player to ork on the cd player
  • Anonymous Jun 13, 2008
    The only problem is that min eis a MP-335
  • Anonymous Aug 07, 2008
    i cannot connect my ipod
  • buie22chris Dec 09, 2008
    I cant get my ipod to work used SRC just goes to the radio, Cd, and standby. Where is the AUX!
  • kedover Jan 15, 2009
    cant get AUX mode to show
  • kleina Jan 20, 2009
    I have the same problem. I bought the correct cable and plugged it in to the stereo, but I can't get to aux, only tuner and standby come up when i press SCR
  • essenmacher6 Jan 29, 2009
    I CAN'T GET MY I POD TO WORK I HAVE THE CORRECT CORD I DON'T KNOW HOW TO TURN THE AUX ON
  • mroper1127 Feb 05, 2009
  • chbulldogs11 Feb 10, 2009
    i cant use the aux output on my deck on tuner cd and standby is displayed
  • slowey674 May 11, 2010
    I have the same "No Aux" option availible. When I hold down the Menu button I get a "Code Set" display and I can't change anything. Any one have this problem?
Yes i had a very similar problem.
I have the MP-235. I could not edit my clock, my subwoofer settings werent active, and I could not switch to AUX.
If you have these problems, you have to hold down the menu button (bass boost) to enter the menu. then scroll around, turn AUX on, change the clock, etc etc.
You turn demo mode off the same way. Kinda silly how they have it all set up.
Hope that helps anyone in the future. i just wasted 3 hrs with this crap!
Posted on Dec 27, 2007
AY THANKS THIS WORKED FOR MY PROBLEM TO
BUT MINE WAS ON DEMO
N I JUST DID WAT THIS TOLD ME TO
THANK YOU
NAST13 BOY
Posted on Dec 22, 2007
I have a kdc 135 and i had the same problem. you have to go to standby mode, then hold down the menu button until MENU appears. then toggle up or down with the button on the right and it will say aux. then toggle left or right to turn aux on/off and then after that when you hit source it will come up as an option.
Posted on Dec 20, 2007
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
Cant adjust the time o the clock
  1. Select Clock Adjustment item during Menu mode (In Standby mode see below for standby mode explained). Select the "Clock Adjust" display.
  2. Enter Clock adjustment mode. Press and hold the control knob for at least one second. The clock will blink.
  3. Adjusting the clock. Push the control knob towards the left or right to select hours or minutes. To adjust each item turn the control knob or push it towards up or down.
  4. Exit clock adjustment mode. Press the (FNC) button.
  • Turn on the power.
  • When the power is ON, select a source.
  • SRC Select mode 1: PRess the (SRC) button and then turn the Control nob or push it toward left or right.
  • To determine the selected source, press the Control knob.
  • SRC Select mode 2: Pressing this button each time switches between sources.
  • Turner ("Turner"), USB or iPOD ("USB" or "iPod"), CD ("Compact Disc"), Auxiliary input ("AUX"), and Standby ("STANDBY")
  • Press at least 1 second to turn off the power
Nov 10, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
When i turn on my indash dvd keenwood player it jus says standby and nothing works
Press the SRC button to turn unit on. The SRC button allows you to navigate between input sources,i.e. tuner, cd, aux, etc. Press and hold SRC button for second to turn unit off ( it will display standby).
Oct 08, 2010 | Kenwood KDC-MP205 CD Player
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
Nov 12, 2009 | Digital Products International ILIVE...
How do i get my ipod to play through the aux line in? i try changing source but only has tuner / cd / standby Thanks
hi their u might have to go into options on ur head deck try holding down a button to display options and hopefully theirs aux input!!!! and make sure ur pluggin into the ipod is in ur earfones hope that sorta helps u cheers.
May 23, 2009 | Car Audio & Video
How to use mp3 with kenwood kdc mp235
turn radio to stanby. hold function key until a menu appears. then switch on aux in. this should alow you to plug ipod in throough aux in on source menu.
May 15, 2009 | Kenwood KDC-MP235 CD Player
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Using the auxillary setting
You'll need to turn the auxiliary function on in the setup menu. Press Source to put the unit in Standby, then press and hold the Menu button for at least 1 second. Press the control switch toward AM or FM until the AUX setting comes up, then press the control switch toward <<< or >>> to change the setting to ON. You can download a user's manual here: http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69
Jun 23, 2007 | Kenwood KDC-MP205 CD Player
Kenwood KDC-MP235 CD Player Logo
1,267 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
