Question about Dell Inspiron 1520 Motherboard
It doesnt boot up. the blue light turns on and then right off
How do I start a Whirlpool duet HT washer?
plug it in, press power button (blue button on left) turn dial to desired cycle then press and hold the blue button on the right until u hear a click then relese. if it doesnt light up the display when u press power the washer is broken.
Mar 11, 2013 | Washing Machines
SHUTDOWN ALL OF A SUDDEN WHEN I'M CHEKING MY EMAIL, I TURN IT ON, STAYS ON, CAN'T BOOT, INSERTED OS TO FIX IT BUT JUST SPIN AND STOP, POWER STAYS ON AND FANS ARE NOT MOVING, BLINKING LIGHT IN MOTHERBOARD,...
what hardware have you replaced? do you hear a beeping sound? try removing everything (HDD, DVD/CD/FLOPPY/)except the proc,video card and mem on the motherboard and try to boot. check if it will give you bios. if it still the same, do an isolation test. the main reason why its not responding is your computer doesnt complete POST. POST is one of the process the computer do to test all the hardware that is connected on the motherboard, if one fails and POST doesnt complete, you wont see the BIOS startup screen. Theres a lot of possible fault on this concern. since theres a lot of things connected on the motherboard
Mar 27, 2011 | Gateway ProfileĀ® 6C (PROFILE6C) PC Desktop
When you switch the laptop on the blue lights on the keybord is on for a few minutes before switched off, but the screen stays black. When you touch over the blue light keys it's turn automatic on? HP...
The touch buttons are there so you can turn your laptop on into the Quickplay feature without having to load into Windows. So basically if you just want to use it for multimedia. If you was to press power button, these will just load straight into Windows. It is meant to do this. If you are saying that the screen doesnt come on when you turn the laptop on and are basically saying that the laptop doesnt boot at all and is just a blank screen, then it is very very likely you have a motherboard failure. Contact HP to see if they have still covered your laptop with warranty as this is a known issue on these laptops and some warranty had been extended
Jul 22, 2010 | HP Pavilion dv6000z Notebook
My phone jus shut off by itself n now it wont turn on. everytime i push the power buton a blue light comes on but the phone doesnt
its odd that it's a blue light, its usually red. if i were you i would try reflashing the firmware. try turning it on in bootloader mode (hold the camera button while powering on it should boot into a rainbow screen ) if that doesnt work then youre screwed, if it does, then you need to find a way to get an official update.zip file or dreaimg.nbh onto the base of your sd card (not in a folder) if you use dreaimg.nbh it will downgrade to the very first release of android, and should update within a couple of days, or you can read up on how to flash firmware and find official updates to download just look on google, theyre all over the place.
Jan 12, 2010 | HTC G1
Eee pc 701 doesnt turn on
Make sure no external devices are plugged in.
If it's still under warranty you will have to return it.
Or take to an Asus support center as it seems to be a hardware problem.
Jul 13, 2009 | ASUS Eee PC 701 Notebook
Computer isnt running
If that is the case your system need to check the battery for fault and does it happen with the power source too i fthe same problem check your processor fan if its bad when you on the system and is not blowing that might have cause the processor itself to get bad you will have to change this ones and then your system will be ok right rate this solution.
Nov 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Laptop doesnt fully boot up!
Question, does it freeze while BIOS boot or operating system boot? try reinstalling operating system and or repairing (overwriting) the MBR.
Sep 11, 2008 | Toshiba Equium 100 PC Desktop
Computer does not turn on
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Getting into Windows Safe Mode To get into Windows 98 / ME safe mode, as the computer is booting press and ... safe mode as the computer is booting into Windows, turn off your computer.
POST troubleshooting steps. Turn on the computer and see if it beeps normally. If the computer has never ... If you're able to get the computer to boot with one or more of the sticks.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T40 2373 Notebook
Black screen blue ring
Try holding the Menu button for about 15 seconds.
Apr 01, 2007 | SanDisk Sansa e260 MP3 Player
Dell Inspiron 1520  Motherboard Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
