Sound No Picture - Televison & Video
  • 3 more comments
  • Steven Rivera
    Steven Rivera Sep 30, 2009
    Samsung S42AX/YB01 Sound No Picture
    Thanks Steve
  • Steven Rivera
    It Is NOT A Phillips Set It Is A SAMSUNG S42AX/YB01
  • Steven Rivera
    The Set In Question Is A SAMSUNG S42AX/YB01
    It Has Sound No Picture
  • Steven Rivera
    Steven Rivera Oct 01, 2009
    I Have Sent This Info Twice Now It Is A SAMSUNG MODEL# S42AX/YB01
    It Has Perfect Sound It HAS NO Picture,
  • Steven Rivera
    WHAT LAMP ??????
    Novelist:
  • 149 Answers
Basic troubleshooting information is needed here...need make, model, equipment connected, etc.
  • 1) Check ALL connections for proper tightness, snapped in securely, etc.
  • 2) VERIFY if possible, using known-good cables from another system,(Ask a friend, call your satellite/cable company if they supply extra cables--lol, plead your case--I did and it worked!)
  • 3) If possible, perform a system reset to return *everything* back to factory settings.
  • 4) Under warranty? Storm recently? Use a surge protector?(If there was a storm there is an excellent chance that the TV will be covered under the surge's warranty!)
  • Anything spilled into, or on the unit? Did someone connect something new recently, a game box, or other such device?(especially if the kids are hooking up their own stuff!!
These items are a start until I get more information, Thanks!--Rick
Posted on Oct 01, 2009
  • 497 Answers
The issue may be with the Lamp of the TV. Replace the Lamp and check.
Good Luck!!!!!!!!!!
  • 17,970 Answers
First of all we'll get rid of the more obvious questions.
Is it plugged in? Is the fuse in the plug OK? Is it switched on? Are the other electrical goods in your place working? Is the cable attached to the TV? Is the aerial in properly (both ends)? Does it work at another socket?
Right, now that those are out of the way we can look at the problem without worrying too much about human error. If there is no sound or picture then the electricity is not getting round the circuitry, which means there is a loose wire/burnt-out diode, or something similar. You need to take it to a TV repair shop.
least try a couple of free attempts:
1.- Hard reset. Merely unplug the power cord and leave it unplugged for 4 hours or more; then try again.
2.- Vibration test. Whack it hard with your hand or fist all around the cabinet in order to vibrate any loose connection or cold solder joint internally. Older sets often have corroded pins in connectors or cold solder joints that start acting up and the vibration will activate them - for a while anyway. WOrth a try.
3.- If the above do not provide any benefit then the only solution is a repair at the local shop. Maybe looking up the blinking code you can get some idea of what the problem is, but in any event when a tv shuts itself off it means the protection circuit has been activated. This activation is from a short circuit in one of the 8 or 10 sections of the tv.
Maybe can send more details about your make and model.
I hope help you with this.
Posted on Sep 30, 2009
  • ZJ Limited
    ZJ Limited Sep 30, 2009
    Video cable came out from the TV or cable box? Or cable is bad... Try a different input and cable.
    Try a hard restart, which simply means unplugging the power cord of the
    TV, and replugging it after 4 hours have passed. This technique
    reprograms the electronics, to a certain extent. If the picture does
    not return, then you have a more serious problem, that requires the
    attention of a TV repairman.
    This may be the backlights and or the backlights power supply is in failure, or the drive board is not working properly.
    The set will have to be serviced. In some models, the backlights are
    not replaceable. In this case they would have to replace the screen.
    The service center can tell you for your particular model.
    If you want to verify the backlights, in a darkened room shine a
    flashlight at an angle in to the screen while the set is running. Look
    at various angles to see if you can see an image. If you can see a
    proper image, this means that the backlights and or the power supply
    for the back lights has died.
  • 10,594 Answers
Please let me know model number and brand of your TV so I will check its schematics, if I have it, to find out possible reason of problem and its solution.
Thanks.
  • Shahid Electronics
    Shahid Electronics Sep 30, 2009
    Thanks Steve
    S42AX seems Philips plasma TV as shown in below service manual image..
    Problem sounds like in power supply board that needs to be replaced.
    I can send you service manual copy if you want to repair TV by yourself or call local TV tech to fix it.
    Thanks.
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
No picture on a hitachi 42edt41
do you have sound but no picture or you dont have sound and picture? if you have sound you need to buy the inverter but if you dont have sound and picture you need to buy the main board
Aug 13, 2009 | Televison & Video
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
No picture no sound
Last night i set childlock in my nikai ( NTV34010) tv set and tuned off by remote control.Then after some time later i tried to turn on tv but there is no sound and no picture.
will u please help me to solve it out.
Dec 02, 2007 | Panasonic CT-36D32 36" TV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
